Old 05-23-2005, 11:38 AM
CNCgr is on a distinguished road
DIY spindle
Has anybody here made a spindle that accepts tool holders himself? e.g. ISO 30 or 40 taper etc?
Old 05-24-2005, 03:28 AM
Bump
Old 05-24-2005, 03:44 AM
cbass is on a distinguished road
I would if I had a lathe (and knew how to use one )...
BTW
What does "Bump" mean?
Carlo
Old 05-24-2005, 04:34 AM
I have access to a lathe and know how to use it. However I would like to know from someone who build one how tight tolerances are needed, what runout to expect etc.
BTW
Carlo
It's meant to "bump up" the post to the top so someone will notice it (push it up).
Nikolas
Old 05-24-2005, 10:28 PM
JRoque is on a distinguished road
Did someone say "spindle"? 8 - )
Start here and follow the link to the details. Hope that helps.
JR
Old 05-25-2005, 07:44 AM
Sure it helps, thanks. My setup is going to be different but it helps to see that it can be homemade with good accuracy.
I plan to use a 3ph motor with DIY VFD controlled from the PC and a belt drive. The taper will be for tool holders, not collects, since I want to make a tool changer with pneumatic drawbar, kind like the picture you posted here
Old 05-25-2005, 01:38 PM
What's the thread for the collet nut?
Old 05-25-2005, 01:42 PM
1.5mm
Old 05-25-2005, 02:16 PM
?x1,5mm
Major diameter?
Old 05-25-2005, 04:32 PM
32 x 1.5mm
What motor brand/model and RPM will you be using?
Cheers,
JR
  #11   Ban this user!
Old 05-25-2005, 04:42 PM
I'm still searching for the right ones. I don't need more than 7K rpm on the spindle. Thanks for the thread info
Nikolas
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 03:57 PM
Diy Spindle Motor Controler miljnor General Electronics Discussion 162 11-06-2009 11:01 AM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 08:01 PM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 10:41 AM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 12:46 PM
