Old 06-11-2010, 04:53 PM
tkoden is on a distinguished road
Milling profile radius discussion
I am an engineer working on improving the manufacturability and producibility of the products my company makes. I got into a long discussion with my boss about the radii inside pockets and on internal corners the outside of a part. I have always modeled parts with radii 15% larger than the expected cutter i.e. .500 EM would have a .25*1.15 or .2875 radius drawn in the model. Is this something that you see a lot in industry or am I the only one that does this? Is it worth the effort to model this way?
Old 06-11-2010, 06:39 PM
mactec54 is on a distinguished road
tkoden
Your thinking & modeling is correct, but you don't have to use quite that much.002 to.010 is enough for the cutter to go around the corner but more is ok to, if your design is ok with a larger radius then do it the way you are, if your boss want's tight corners then you will have to use a smaller percentage, an Outside radius does not need to change only if you want to maintain a wall thickness, Like inside radius .260 wall thickness .125 outside radius would be .385
Mactec54
"Radius to end of arc differs from radius to start on Line #" labuda G-Code Programing 8 11-15-2009 06:35 AM
Need Help!- Radius to end of arc differs from radius to start? Jamy LinuxCNC (formerly EMC2) 2 08-22-2009 11:28 PM
Need Help!- PROFILE MILLING ON MATRIX LATHE cncmessiah Mazak, Mitsubishi, Mazatrol 1 03-21-2009 10:22 AM
RFQ - Alum profile w/tight radius bobborck Employment Opportunity 2 09-08-2008 01:16 PM
2d milling with radius linking zcases Mach Wizards, Macros, & Addons 0 11-15-2005 10:47 AM
