Old 06-10-2010, 02:47 PM
Chester3000 is on a distinguished road
I need to pick out CNC Mill and Lathe by tomorrow (6/11)!!
My professor at my school (Oregon Institute of Technology in Portland) just informed me this morning that they received a large sum of money this week and they need to spend it by tomorrow (6/11)!
He has put me in charge of picking out a new CNC Mill and Lathe.
He wants me to pick out a user friendly CNC Mill in the $7000-$10,000 range.
He also wants me to pick out a small Lathe or a small CNC Lathe in the $3000-$3500 range.
So, any suggestions?
I need to give him the make and model and ordering info by about 2pm tomorrow (6/11)...
Any help would be greatly appreciated!!
It would be great to get some professional input on this purchase!
Thanks!!
Old 06-10-2010, 03:06 PM
awerby is on a distinguished road
It would help if you said what you had in mind to do
with these machines. But for a "user-friendly" mill, it's hard to beat Roland's MDX-40, the designers of which have endeavored to make it operate as much like a desktop printer as possible. It's enclosed for safety, has automatic Z zeroing, includes all the software you need to create parts from 3d CAD files, and optionally comes with a rotary 4th axis and tailstock assembly. And even with that option included it comes in pretty close to your budget numbers, especially with the discounts I offer.
There aren't many CNC-equipped lathes in your price range, but you could get a Sherline 4000A CNC system, which is small but well-constructed, and includes a range of accessories. The control software is called EMC, which requires a computer to be loaded with the real-time Linux OS, but that's free. Give a call if you really want to order these machines in a hurry...
Andrew Werby
www.computersculpture.com
Thanks!!
Old 06-10-2010, 09:25 PM
It will be a general use machine.
Mostly we'll be machining aluminum, steel, copper, plastics, foam, and....?
We are an engineering program, so I'm sure it will be used for all kinds of prototypes and projects
Also, after some quick research we figured out that $10k may be a little low for the size of machine we had envisioned...so I convinced them to up the budget to $18k!!!!
So, whats a good cnc mill for $18k?
As for the lathe, we got the budget up to $5k!!
Any suggestions are a great help!!
THANKS!
Old 06-10-2010, 09:37 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
http://www.haascnc.com/details.asp?I...M#VMCTreeModel
this will get you more into real cnc's , they may give an educational discount
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 06-11-2010, 08:04 AM
rowbare is on a distinguished road
For the mill, you might consider:
Tormach PCNC 1100 or 770 : http://www.tormach.com/ I would choose one of the packages and add a power drawbar.
or
Novakon NM-200 Series 2: http://www.novakon.net/nm-200proseries2.html
or
Mikini Mechatronics: http://www.mikinimech.com/index.html
If I had the money, I would like a CNC lathe like this:
http://www.machinetoolonline.com/PM-1330CNC.html
One of the advertisers here sells a lathe conversion: http://www.microkinetics.com/lathe1236/
bob
Old 06-11-2010, 11:02 AM
Jay1Firm is on a distinguished road
Try looking into some used Haas machines. They make a fairly good machine for the money.
Old 06-11-2010, 11:09 AM
mcphill is on a distinguished road
or
or
bob
Totally agree with those CNC Mill suggestions. I would go for a 4th axis with whatever you decide. I am leaning toward the Mikini, but everyone has their own opinion on what is "best". I think without a doubt the Mikini would be the "cleanest" as it is the only machine that is fully enclosed in that price range.
I have no idea on lathes, so am eager to see other user's opinions!
Let us know what you buy, and post up again in a few months with how things are working out!
Old 06-11-2010, 12:55 PM
Ok, I'm getting closer to a decision!
In no particular order:
-The local Haas dealer is looking into some options for me
Most liklely the TM-1
- http://www.tormach.com/Product_PCNC_main.html
- http://www.novakon.net/nm-200proseries2.html
- http://www.syilamerica.com/machine_x7plus.php
- http://www.microkinetics.com/express/index.htm
- http://www.ihcnc.com/pages/cncoptions.php
- http://www.mikinimech.com/1610L.html
Only 3 hours left to decide....
Old 06-11-2010, 01:10 PM
Its kinda hard to say what machine you should get without know what your application needs will be for the machine. A few of these machines are generally for drill applications and very, very light milling.
Old 06-11-2010, 01:47 PM
Again, it will be a general use machine.
Which of the machines are "generally for drill applications and very, very light milling" ?
We definitely want to be able to do some milling! We don't necessarily need to do heavy machining but just some general use.
I really want to steer away from a machine that can only do very, very light milling.
So please give me more info!
  #11   Ban this user!
Old 06-11-2010, 02:14 PM
Well Chester, I wont knock them, cause I haven't really run any of those machines except a similar machine to the IH http://www.ihcnc.com/pages/cncoptions.php
. You can generally tell the machines that are more built for milling are machines with good framing. The more rigid the machine looks around the Z axis the better it should mill without too much chatter issues..Good luck with you choice and let me know what you decided and how it works for you.
I usally post some tips if your interested.
http://cnc-machining-engineering.blogspot.com/
So I've got $15k to pick up the best CNC mill / VMC for my money... motoguy Want To Buy...Need help! 2 05-10-2010 12:31 PM
Pick-and-place using a CNC mill mickelsen CNC Tooling 2 12-23-2007 07:02 PM
Trying to pick a lathe (UK) djh82uk Mini Lathe 3 11-21-2007 06:21 AM
about to buy 7x lathe, help me pick out some tooling draculia Mini Lathe 6 04-02-2006 05:38 AM
Help to pick small (not mini) CNC Lathe 5axis General Metal Working Machines 5 02-03-2004 05:35 PM
