Old 06-08-2010, 10:55 AM
hudsonlighting is on a distinguished road
Milling Aluminium with a high speed router
Hi guys,
Is there any guide to milling aluminium with a high speed router? I have a CNC router from RoutoutCNC but the routers minimum speed is 10,000 rpm. As I understood it you need to mill metals at much slower speeds. I plan to use a 4mm steel with Ti coating 4 flute end mill. Any help would be appreciated.
Old 06-08-2010, 11:01 AM
4mm diameter will be fine at 10,000 rpm, you could even go faster. Just use coolant/lubricant and preferably a two flute cutter to give better chip clearance.
Old 06-08-2010, 11:17 AM
Thanks for the reply, any idea on approximate feed rates?
Old 06-08-2010, 11:28 AM
Khalid's Avatar
Khalid is on a distinguished road
SPindle RPM: 24243
Cut Feed= 484IPM
for the mentioned cutter... At 10000you can CUT at 150IPM..
PS:
Don't act on my figures you can loose the endmill
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 06-08-2010, 11:29 AM
With a cutter that small only about 0.2% to 0.4% of the cutter diameter is safe, depending on your depth and width of cut. That gives around 2 metres per minute feed; which seems fast so maybe go a bit slower.
Old 06-08-2010, 11:41 AM
Khalid's Avatar
for DOC i will suggest you to use value of=1/4 x dia of cutter.. in your case it comes out 1mm....
Old 06-08-2010, 01:57 PM
spoiledbrat is on a distinguished road
Use WD-40, and listen to the router. If the tool clogs up, you will notice a slight change in the sound. Stop cutting, and clean the tool. Aluminum seems to melt/smear onto the carbide. Once clogged, it will break off.
Rob
Old 06-08-2010, 02:04 PM
Khalid's Avatar
Also use helical or ramping entry..do not plunge directly.. we want to save You, your tool, machine , workpiece and offcourse our time for after-effect discussion
Best of Luck
Old 06-08-2010, 05:13 PM
Thanks very much for all your help guys!
Old 06-08-2010, 06:25 PM
diycnc is on a distinguished road
i router aluminum with 3/16 end mill at 18000 rpm 1000mm/m single oflute onsrud bit 63 series, 1/16" doc
i find on our machine anything more than one flute seems to plug up and is not suitable for production type work, we also have a air mister.
___________________________________________________________________
http://www.cnczone.com/forums/showthread.php?t=86985 my work in progress
Milling a high speed spindle mount Jay C Videos 1 08-16-2008 11:34 AM
High speed spindle for milling thackman Benchtop Machines 11 12-19-2007 12:24 PM
High Speed CMS FOAM 5-axis milling machine fairlane77089 Hard and High Speed Machining 4 06-05-2006 10:09 AM
High Speed Hard Milling MachineSMM Hard and High Speed Machining 24 03-27-2006 06:31 PM
High-Speed 3 (4?) axis cnc router rherman DIY-CNC Router Table Machines 29 10-20-2005 10:31 PM
