Old 06-08-2010, 09:51 AM
hrhoward is on a distinguished road
Help with identifiyng Southbend Magnaturn
Hello.
We have a Southbend Magnaturn lathe. I believe it is a 1218 or a 1220, I do not know which. It has two floppies on the front and a hard drive inside. The hard drive is failing, fast.
The serial number is 00151.
This machine has seen very little use.
I could use some specs on the thing; travels, spindle rpm, types of servos, etc...
I could also use some recommendations for a possible retrofit.
Thanks,
Heath
Name:	Southbend - Bridgeport CNC Lathe 001.jpg‎
ID:	108748   Click image for larger version
Name:	Southbend - Bridgeport CNC Lathe 004.jpg‎
Old 01-15-2011, 04:09 PM
novice5 is on a distinguished road
Looking for a magnaturn post processor
You can find the specs for the machine by just doing a search for southbend 1218. There is a machine sale site that has specs on most cnc machines. The specs are free at the site.
Need Help!- southbend magnaturn 612 cidteach Mini Lathe 3 01-15-2011 04:13 PM
Southbend Repair or 10x22 2_many_hobbies Mini Lathe 2 01-03-2010 12:22 AM
Southbend Lathes cmnewcomer General Metal Working Machines 7 07-18-2009 03:53 AM
Southbend 9" dial thread indicator BillTodd Metal Working Tooling 0 08-31-2008 02:45 PM
MagnaTurn 612 dustydragon General Metal Working Machines 1 10-09-2007 08:37 PM
