Old 06-07-2010, 07:47 AM
byrdo is on a distinguished road
Negative Buttress
I have an internal and external modified buttress thread with a -3 degree trailing angle and a +45 degree lead angle. I would like to use a full profile insert and program for a -3 degree in-feed. Is this possible using G76? I believe I can program it long hand with a G32 cycle!? Does anyone else have experience with this type of thread? If so, how did you machine it? Machining on a Citizen C32 type 2M8 with a Mitsubishi Meldas control.
Tags
buttress, g32, g76, negative
5 volt positive and negative?? Rooney Automation Technology Products 4 05-07-2009 04:04 PM
Need Help!- G53-Z SHIFT AMOUNT NEGATIVE coondog Daewoo/Doosan 3 05-16-2008 10:21 PM
Modified 3.5"-5 O.D. Buttress Thread nitemare General Metalwork Discussion 5 01-17-2008 12:51 PM
Verification of negative posters rocket67 Suggestions for the CNCzone.com site. 8 11-23-2007 03:25 PM
G83 + G72 with negative return plane drewmeister Haas Mills 2 02-20-2007 06:21 PM
