Old 06-05-2010, 01:24 PM
vsmi is on a distinguished road
Need help going from Fanuc yellow cap to red cap
Hello,
Looking to replace a Fanuc 10M yellow cap with an Alpha series red cap (may move a rotary 4th to a different machine). I haven't been able to remove the existing motor yet to see the shaft configuration, but was able to get the number off the nameplate. It reads "A06B-0651-B011#0003 (2000M)" - I was told an Alpha 12 would replace it but I don't know the shaft configuration, etc. Does anyone know the Fanuc servo motor nomenclature - I'd like to price a motor before tearing things apart. Thanks.
Old 06-22-2010, 08:30 AM
Al_The_Man's Avatar
The B011 the 0 normally indicates a taper shaft motor.
I noticed in the 'Other' board you asked about changing the encoder on a redcap, they are keyed and secured by a 5 or 6mm Allen head screw down the centre, they take a bit of a twisting to get it off the taper, but usually very easy.
They can be replaced on the key either way as they are 8 pole motors so the encoder works in either position.
Yellow Screaming Meemee MrWild Benchtop Machines 0 02-05-2010 10:39 PM
Need Help!- Tuning Fanuc, Yellow Cap DC servo's BodylinezCNC Fanuc 0 07-09-2009 07:25 PM
Yellow cap motor part's Kevin Taylor Fanuc 2 11-25-2007 12:36 PM
Yellow Iridite Pens ??????????? CAMCRASH Mass finishing equipment/media/stratigies 1 06-12-2007 06:34 AM
FANUC "Yellow Cap" servo motors -buzzing noise brgrii Fanuc 2 06-03-2007 08:21 AM
