Old 06-04-2010, 12:56 PM
cedarpeaks is on a distinguished road
X Backlash
Have Leadwell MCV1300. Currently experiencing .03 backlash in X. Have isolated problem to ball screw movement. Any suggestions on how to proceed with resolving this matter.
Old 06-04-2010, 02:43 PM
Andre' B is on a distinguished road
Sounds like you need new thrust bearings.
Old 06-06-2010, 11:47 AM
dale1639 is on a distinguished road
Backlash
Well you need to isolate the problem, if you can place an indicator at one end of the ball screw with a ball baring in the centering hole (use small amount of grease to hold ball) and then move the axis back and forward if the screw moves check thrust bearings if doesn’t move check ball nut. It might be both. You need to check gibs or linear bearings also
Backlash Compensation / Backlash dwessels Benchtop Machines 58 02-23-2009 10:27 AM
BACKLASH??? ALEXCOMO Fanuc 1 04-12-2008 10:32 PM
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 03:35 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
backlash MIKE JEFFERS Benchtop Machines 4 04-21-2005 11:26 PM
