Old 06-03-2010, 05:21 PM
ceilingwalker is on a distinguished road
ATC wont reference
Good day. I have a Mori Seiki vertical machining center that I'm having trouble getting it to ref home. I can't perform a tool change because either the magazine or the arm aren't registering a ref position. When I try to mdi a tool change it wont do anything more than drop the pot. Machine was e-stopped during tool change. Thanks for the help.
Old 10-28-2010, 09:18 AM
2wheelferrum07 is on a distinguished road
if you are able to zero return the Z and orient the spindle you should be home free, but that is a big if.
try M33 (all tools in mag)
zero return the Z and then mdi m19 and then M33 or any tool change
G30 Reference Positions stevo1 Fanuc 5 11-06-2008 12:48 PM
Need Help!- over travel in x at reference Don H Hardinge Lathes 3 10-18-2008 10:12 AM
Scripting reference... kiwichris NCPlot G-Code editor / backplotter 5 11-15-2007 03:36 PM
Reference positions in DIY CNC davidp General CNC (Mill and Lathe) Control Software (NC) 4 05-23-2006 02:48 PM
Programming Reference jhwatts General Metalwork Discussion 6 10-19-2005 02:37 AM
