Old 05-30-2010, 06:03 PM
dws_engineering is on a distinguished road
Help needed with lathe romi ez path emergency stop
Hello,
I'm having trouble with my bridgeport ez-path series 1 lathe.
The emergency stop error message keeps flashing up on the screen, with hit (key) to clear. And wont clear.
I can bypass this message by manually pushing the button in on the 24v relay and then the message clears. hovever,, when you go to home the machine the slideway comes past the limit switch then comes back. Then the screen will come up with.... following error limit exceeded.
The bmdc card is comunicating with the auf board and all the drives work manually. Its just strange why the relay wont come on on its own.
any help would be great.
thanks
Dave
Old 07-19-2010, 08:18 AM
elecmfgco is on a distinguished road
Our EZPath has similar symptoms.
Did you ever find a solution?
Old 11-14-2010, 01:11 PM
Hello ,
I'm affraid not, the dam thing is still in the workshop doing nothing.
got yours sorted yet?
thanks
Bridgeport/ROMI EZ Path Lathe mcsf General Metal Working Machines 3 12-13-2010 07:55 PM
Help needed with lathe romi ez path emergency stop dws_engineering Bridgeport/Romi Lathes 1 06-11-2010 08:35 PM
Need Help!- Bridgeport EZ path romi lathe dipiazza General Metal Working Machines 0 12-04-2008 09:48 PM
Need HELP on Bridgeport EZ-Path ROMI Lathe Michael Esch Machine Problems, Solutions , Wireless DNC, serial port 6 04-09-2007 10:38 PM
Romi EZ Path Lathe kenski General Metal Working Machines 2 07-21-2006 09:25 PM
