Old 05-18-2005, 03:59 PM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Proper Method To Shim?(for Tramming)
HEY EVERYONE,
I'm soon going to be tramming the head on my h.f. (rong fu). Any methods or need to knows for this process. I was thinking of using some feeler gage material for this, if shim stock is too expensive. Any comments?
Old 05-18-2005, 07:27 PM
Mcgyver is on a distinguished road
KBC used to have a shim stock kit for 20 or 30 dollars cdn - assortment of brass shim, each around 4" x 12". if the no longer have it, others must have something similar
Old 05-21-2005, 02:48 PM
haysys is on a distinguished road
Shim Stock
I bought several packages of brass shim stock at my local Ace Hardware store about a year ago. I was bale to buy .001, .002, .003,... in sheets about 4"x6". It's worked great for my needs.
Old 05-23-2005, 11:46 AM
FLUTE HEAD's Avatar
Gold Member
THANKS GUYS,
I ended up shimming with some feeler gage I already had. Discovered that when the spindle sleeve was locked it through it off 2 thous. When doing cnc work it won't be locked, so I shimmed "true" in the unlocked position.
Best method to make this Moondog General Metal Working Machines 14 10-07-2004 06:49 AM
Proper Planning Prevents Poor Performance CamIam DIY-CNC Router Table Machines 2 04-01-2004 08:09 AM
Proper Computer and Chip for Mach 1 HomeCNC Mach Software (ArtSoft software) 12 03-17-2004 10:14 PM
Structural Debate: The Best Linear Motion Method CNC Brute DIY-CNC Router Table Machines 3 11-22-2003 11:10 AM
Best Method musky2much WoodWorking 1 10-13-2003 09:59 AM
