Old 05-25-2010, 04:10 PM
Tymawr is on a distinguished road
Smile Estop on inverter
I’ve just brought a milling machine which is 3 phase and comes with a IMO Jaguar Cub inverter to use on single phase. Can anyone tell me where to connect a N/C or N/O emergency stop switch to the inverter in order to stop the motor. I’ve been trying to make sense of the manual and I’m still baffled ?
Regards
Glenn
Old 05-25-2010, 04:23 PM
Al_The_Man's Avatar
In the absence of a stop input, it would appear that a N.C. contact from CM in series with the FWD/REV would do it, it if the E-stop opens up the N.C. contact on a control relay etc.
Old 05-25-2010, 05:45 PM
Karl_T's Avatar
Karl_T is on a distinguished road
This may prove I'm an anal engineer. For industry, Estop must stop broken machines also. For example, if somebody misprograms the stop parameter in your VFD, you no longer have an Estop button.
Because of situations like this, put a motor contactor or large relay in front of every device that moves the machine. Estop then kills power to the coil on all these relays.
If you're doing your own machine, i guess you don't have to follow industry standards.
karl
Old 05-25-2010, 06:13 PM
Al_The_Man's Avatar
That's True, a contactor on the input should also be used as the manual states it shows it as MC2.
But also a method to stop the Fwd/Rev from automatically being reset on E-Stop release.
IOW, a N.C. contact used in the CM string should be manually reset.
I don't see any other stop button in the manual?
estop eloid General Electronics Discussion 8 02-15-2009 08:23 PM
Estop and limits krymis General Electronics Discussion 1 02-18-2008 05:39 PM
random estop erase42 DeskCNC Controller Board 21 02-02-2007 05:28 PM
Estop HuFlungDung CamSoft Products 5 03-06-2004 01:24 PM
