Old 05-21-2010, 09:22 PM
chns is on a distinguished road
CNC Mill motion problem
Hi. I'm running a script to make a thread by helical interpolation (so it is a bit taxing to the X and Y motors I guess?), and each time all 3 motors seize up part-way and start spazzing out (they don't seem to undergo any net movement, but they start randomly pulsing). I've tried this 3 times and each time this happens about halfway through the script.
So here's what I'm running/the list of candidates for what's messing up:
Mill: X3 with CNCFusion CNC conversion
Steppers: Keling NEMA23 on each axis (KL23H286-20-8B)
Power Supply: Keling KL-320-36 36V/8.8A
Motor control: Geckodrive G540
Software: Mach3 on WindowsXP
At first I thought one of the motors might be overheating because they were getting pretty hot, but after clamping some heatsinking to them I still had the same problem.
All 3 motors seem to lock up simultaneously. Even when I stop the program or try MDI control they don't respond and just keep spazzing. After a few tens of seconds of this the Gecko G540 finally throws a fault and the motors stop.
Given that all motors seize, I'm guessing the problem is the Gecko G540?
Has anyone experienced anything like this? Anyone have any recommendations/diagnostics/advice? Thank you for your help!
Old 05-21-2010, 11:18 PM
Fastest1 is on a distinguished road
I wonder if the load for the 3 combined steppers is more than the PS can put out? I cant imagine the helical interpolation being that much more taxing than just threading.
Old 05-21-2010, 11:29 PM
Hm, I made sure to get a PSU that's overkill for what I'm using it for so unless its dying I don't think that's it (would that cause these symptoms with all 3 motors going spastic like this?). This isn't the first time I've run such a routine... just the first time I've had problems :-/
Old 05-21-2010, 11:41 PM
I typed first and thought more later. It probably wouldnt cause the same issues. I was just guessing out loud. I would think 1 driver would get a weak signal not all 3. I have all kinds of problems on a regular basis. I wish something would happen consistently, then maybe I could figure out what I am doing wrong!
Just IN- Doctor Bearings Provide Constant Linear Motion in Paper Mill Since 1992! Pacific Bearing Product Announcements & Manufacturer News 0 06-09-2009 01:59 PM
A problem with my taig mill? Or with me? 725franky Taig Mills & Lathes 18 11-08-2007 12:42 PM
Series 2 BOSS 6 Axis motion problem craig96us Bridgeport and Hardinge Mills 43 01-14-2006 11:06 AM
Kerk Motion Leadscrew Possible Problem ThomasAlva Mechanical Calculations/Engineering Design 2 01-27-2005 12:17 PM
MaxNC motion kit for Sieg X3 mill? replicapro General Electronics Discussion 3 06-16-2004 12:24 AM
