Old 05-20-2010, 04:36 PM
hotrob1 is on a distinguished road
Drawbar removal
We have a Mighty Viper 950 w/Fanuc controls. We need to remove the drawbar to check the washers, etc. as we are having trouble with some loose tooling. The clamped/unclamped works great.
We have the pnuematic cylinder removed. We understand the drawbar assembly slides out the bottom of the spindle. How do you remove the drawbar? Is there a nut or two that has to be loosened or removed? Any info will be appreciated.
Thanks in advance.
-Hotrob1-
Old 05-24-2010, 11:40 AM
Drawbar
We got it. The main nut was locked down and did not have the wrench. We got it off and tapped on the drawbar. FYI - slides out the bottom. Removed all 180 washers via magnet. Now time to replace...........
-Hotrob-
Old 06-02-2010, 03:53 PM
Correction
We removed 108 spring washers and found several broken causing loose tooling. Replaced washers and drawbar. Making parts, now!
Broken tap removal lager1978 General Metalwork Discussion 2 08-07-2009 08:36 AM
Slag Removal? + d CNC Plasma and Waterjet Machines 3 03-15-2009 06:26 PM
R8 spindle pin removal krymis Industrial Hobbies (Support forum) 37 01-08-2007 07:42 AM
tm-1 handwheel removal? superrat Haas Mills 6 11-10-2006 09:52 AM
Quill removal HOSS Tree 2 08-08-2006 06:21 AM
