Old 05-19-2010, 01:21 PM
hotrob1 is on a distinguished road
190 generator overheat alarm
We got a Hitachi H-cut 304P w/ SP230 Fanuc controls. The machine is coming up with a '190 - generator overheat alarm'. We had the AVR checked out and it is ok.
Any other suggestions or where to look?
Thank you,
-Hotrob1-
Old 06-02-2010, 03:56 PM
Update
We actually repaired the AVR and a Fanuc power supply. We replaced several fans that were not working and killing the 110Vac. Traced alarm through several connections/boards to the backplane housing the I/O card. We pulled the card and found an open resistor. We replaced the resistor and re-installed the I/O card. Powered up and no alarms!!!
-Hotrob1-
Old 02-21-2011, 04:04 PM
woody_cnc is on a distinguished road
hi Rob, in your post I saw that you have similar issues with the 304P as we have over in our workshop as we have only just started working with it. Do you happen to have the operating manuals, that could include diagrams?
thanks
woody_cnc
Newbie- Y Axis Overheat GM81 Fadal 9 09-27-2009 10:59 PM
scr dcm overheat??? protrxrptr17 Fanuc 1 09-02-2009 09:10 AM
Need Help!- VF2 - Control overheat 122 alarm?? DaOne Haas Mills 27 05-28-2009 08:11 PM
Need Help!- Regen overheat engine tech art Haas Lathes 7 02-05-2009 09:31 PM
Mitsubishi IPM overheat alarm rjboz Daewoo/Doosan 4 12-22-2006 02:46 AM
