Old 05-19-2010, 06:35 AM
rward1961 is on a distinguished road
Haas
I have a haas rotary it is a TRT 210 and my b axis is giving a hi current alarm. I found 3 different dip switches on the mother board and thought that one might need adjusting. Has anyone ever have this happen and knows how to fix it. any responce would be helpful, Roland
Old 05-19-2010, 08:36 PM
abhthree is on a distinguished road
we have old haas 4th axis rotary tables. They give a hi current alarm when the face plate is too tight. If they were taken apart to be cleaned and not put back together with the right torque we would get this problem. Never figured out a good way to fix other than fiddling with the face plate. Hope this helps.
Old 05-24-2010, 02:25 PM
Maintexpert is on a distinguished road
trt 160 repair
First make sure the solenoid to the break is working.
if thats ok then you may try taking all wire connections appart and cleaning them. If that does not work you may wnat to check the brushes on the motor 4 of them. last but worst motor.
haas SL-20 to Haas bar 300 alignment plate needed J-Mccoin 2009 Haas Lathes 2 12-02-2009 09:13 PM
RFQ haas SL-20 to Haas bar 300 alignment plate needed J-Mccoin 2009 Employment Opportunity 0 10-28-2009 02:17 PM
Haas Super Mini-Mill and Haas Trunnion Table Gabe Newell Haas Mills 6 06-07-2009 01:23 PM
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
HAAS Service HAAS Repair NY NJ CT PA serviceman Product Announcements & Manufacturer News 1 01-04-2008 03:27 PM
