Old 05-16-2010, 06:29 PM
theanswers is on a distinguished road
Excel 500 Lathe Problem
I've recently purchased a excel 500 Metalworking lathe. However I am somewhat alarmed by a noice coming from the main headstock. In certain gears it's as if some of the gears within the headstock are loose and banging about. This obiously isnt normal. I've checked the oil and it appears to be low. Would it be a lack of oil causing this or would there be something more serios wrong?
Looking forward to your replies and advice
Peter
Old 05-16-2010, 07:40 PM
Al_The_Man's Avatar
Banging noises are not good, often there is a cover of some kind you can do a bit of visual inspection, chipped gears cause noise or a gear loose on a lay shaft etc.
Engage the gear you have the problem noise with when you remove the cover.
Old 05-17-2010, 05:09 AM
Now the fault is within the headstock. I.e. directly behide the area where the levers are to change the speeds. Is this the area you are talking about? I hope to open it on wednesday and try and identify the fault. Should one top the machine up with oil first or wait until i have a look?
Any other tips or advice?
Old 05-17-2010, 10:29 AM
Al_The_Man's Avatar
It is often easier to drain the oil when you inspect it, otherwise you may miss something.
I had a problem on a mill gear head where the bronze gear index fork had worn allowing the shifted gear to still be partially engaged.
In this case I S.S. a new bronze piece on.
Excel / Kiwa 510 VMC Fanuc 0M) ATC Problem MotoDan Fanuc 20 08-03-2010 02:25 AM
Need Help!- Any Excel/VBA Experts out there to help me with an Excel G-Code Macro? HankMcSpank G-Code Programing 3 02-18-2010 07:58 AM
DXF2DAT in MS Excel arman Foam Cutting Software 0 01-03-2007 01:36 PM
Excel 810 Dale283 Fanuc 0 01-15-2006 05:47 PM
Using Excel for Gcode itsme G-Code Programing 7 02-10-2005 01:34 PM
