Old 05-15-2010, 09:26 AM
Khalid's Avatar
Khalid is on a distinguished road
RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL
This is first time i am working on CNC retrofit of a Radial Drill Machine. The existing machine is manufactured by Pakistan Machine tool Factory with a working area of 340x 340mm. Presently, the machine is under major retrofit with latest 3-axes CNC Control System. The controller will be able to do 2D and 3D contouring of complex shapes with higher accuracy, less resources and less time.
This retrofit will help us making complex parts for fabrication of 10ft x 10ft CNC Milling machine.
SCREW REPLACEMENT
Currently the Machine has ACME screws at X/Y cross slides. To get optimum accuracy and low-backlash these ACME screws will be replaced with Ball screws.
CUTTING FLUID CONSOLE
For High speed machining cutting fluid is abundantly required on the work piece. New Console was fabricated using in-house facility. The pump will be controlled with the help of computer M-code command.
CROSS-SLIDES
Cleaning of linear ways and minor modifications for ball screw installation is underway.
STEPPER MOTOR PULLYS
The machine will be driven with stepper motor. These stepper motors will be installed on X-Y Cross-slides and Spindle (Z-axis). Stepper motor pulleys with 3:1 reduction has been machined.
SPINDLE OVERHAULING
The spindle of this machine can carry tools up to 13mm diameter. The ranges of the spindle RPM is from 251~ 2560. The spindle is driven with 3-phase 2.2hp motor. Spindle gears and internals are currently being overhauled. One of the roller bearing was replaced due to high noise and clearances. We have minor backlash in the collet-shaft rack-pinion gears However; this backlash may be compensated in the controller software.
I hope you will enjoy the thread and comments...
Name:	Machine original.JPG‎
ID:	107227   Click image for larger version
ID:	107228   Click image for larger version
ID:	107229   Click image for larger version
ID:	107231   Click image for larger version
ID:	107232   Click image for larger version
ID:	107233   Click image for larger version
Name:	Coolant Console.JPG‎
ID:	107235   Click image for larger version
Name:	pump flood.JPG‎
ID:	107236   Click image for larger version
Name:	BS closeup.JPG‎
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 05-15-2010, 11:55 AM
Khalid's Avatar
Some more advancements
Installed the counter weight on the Quill.. Have ready X/Y carriage for stepper mounts.. A little work on enclosure today...
ID:	107242   Click image for larger version
ID:	107243   Click image for larger version
ID:	107244   Click image for larger version
Old 05-17-2010, 09:02 AM
Khalid's Avatar
I have installed stepper Motors and calibrated the slides.. I am getting 0.4mm backlash at X-axis (The bottom carriage) and 0.17mm at the top carriage.. After backlash compensation I am getting 0.02mm tolerance at the bottom carriage and 0.001mm at the top carriage...
I am really very happy with the results... The above tolerance values were checked within 10mm of screw travel.. I will check the Precision/Foot of the carriage tomorrow..
However, I have checked by travelling back and forth several time and my values are consistent within the above mentioned range...
Old 05-20-2010, 04:26 PM
Rene Nuñez Paz is on a distinguished road
Hi Khalid, Nice work.
Congratulations.
Regards
Rene
Old 05-21-2010, 06:06 AM
Khalid's Avatar
Hi Rene,
thanks...
Currently I am getting problems in calibrating the Z-axes... When I using Mach3 to setup it in 'MM' metric unit..I am getting 12.344 steps/mm... This is very course I don't know why?
My Motor is = 200 steps
Gear Reduction 3: 1
I am using 1/2 step mode...
I don't know what is driving the quill but it is something Rack and pinion, i don't know the specification..
so the mathshould be simple...
200 x 2 x 3 x Y= 1200 x Y.
but Mach3 only returning me 12.33 steps!!!!!
What should i do?
Old 05-21-2010, 08:35 AM
Hi Khalid
Attach a table.
Hope this helps you.
Let me know
Regards
Rene
PD-I was been very busy, I want to finish embroidery structure soon as possibler, next week weekend arrives new cnc controller for diy embroidery machine and a singer embroidery press foot.
Old 05-21-2010, 08:53 AM
Khalid's Avatar
Thanks REne..
I am checking the spreadsheet... If I am getting 12.74steps/mm then what resolution i can achieve on Z-axis?
Nice to hear about the controller and embroidery machine..Currently I abandoned the software project.. You keep working on it..When your research completed i will ammend in embroidery software...
Old 05-21-2010, 12:52 PM
Hi Khalid
As I understand, resolution is a movement than we can get
In one step, in this way your resolution will be
= 1step / 12.74step/mm =0.078mm
Tell me if this is wrong.
Regards
Rene
Old 05-23-2010, 02:04 AM
Khalid's Avatar
Here i want to show the completed machine with failed attempt of drilling in Carbon steel plate.. I am getting very less torque due to coarse ratio of gearing.. I am going to install Worm-Wheel arrangment on Z-axis soon..
Name:	Cross slides.jpg‎
ID:	107675   Click image for larger version
ID:	107676   Click image for larger version
ID:	107677   Click image for larger version
Old 05-23-2010, 12:26 PM
Hi Khalid
Nice project.
What kind of steppers are you using?
Some day I want to do like you with my drill press
I need a 48 hours day.
Regards
Rene
  #11   Ban this user!
Old 05-25-2010, 11:29 PM
Khalid's Avatar
Hi Rene, I am using NEMA34 1200 Oz-in (Bipolar mode)stepper...but i am using these stepper in Unipolar mode so getting aroung 750 Oz-in torque... Yesterday I removed the Automatic Feed gearing and now with one revolution i am getting 0.0016mm Feed
and with a lot of torque...
  #12   Ban this user!
Old 05-26-2010, 09:43 AM
Smile
Hi Khalid
This is a lot of torque!! Now you can mill a lot of pieces for future projects
including a small pieces for embroidery project,, sorry we are living at very long distance.
Congratullations for this good and almost concluded project.
Seriously asking,,, do you think to come back to embroidery project?
Iam not refering only about promised update of software, also I'm refering to finish your own embroidery machine, and after, work for change to continuous running motor, and make all improvements as possible. Iam working a lot reading, investigating and writing an algoritm for running continuos motor and asking a lot in Mach forum,ecc.
I recopiled, optical switches, small stepper motors, belts,solenoid, buy a new CNC controller and a mini DC relay for motor and solenoid control.
I know that you are involved in a multipled projects, and this make me happy, you are a big inspiration about all is possible to do using small resourses,( 4th axis, laser scanner, ecc).
For my part I don't have promgramation knowledge, but I can use my time for continuing bulding embroidery machine, testing new components, and work methods. Then I can make new sugestions for do the best in project.
Regards
Rene
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Anyone in the East Tennessee area doing a mill drill retrofit..... pete from TN Benchtop Machines 0 05-04-2008 08:00 AM
Yoshida Radial Arm Drill Press jnsane84 General Metal Working Machines 0 02-07-2008 01:31 PM
Where to begin? Retrofit a Stepper Control to a Mill-Drill? pfeist General Metal Working Machines 9 05-04-2004 05:44 PM
CNC retrofit for Mill/drill? Jkier General Metal Working Machines 10 07-03-2003 06:42 PM
