Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 59
Thread: RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL
  1. #37
    Registered Zygoat's Avatar
    Feb 2010
    how exactly was this accomplished? where can i find more info?
  2. #38
    Jul 2003
    Holmen, WI
    what kind of info are you looking for? In the simplest form - you need 3 inputs open to read the encoder. within emc you virtually hook up a few pins that connects the encoder to the guts of emc. If you are using the printer port for reading the encoder - you are limited by how fast the computer can count. Say you have a 100 line encoder on the spinde (400 quadrature) on decent computer hardware you should be able to count into the 20-40khz range. so - you should be able to count up to the 3000 - 6000rpm. As long as the axis can keep up with the spindle reversal - you are golden.
    There is a lot of cheap interface hardware out there for emc that will move the encoder counting and pwm outside of the computer which doesn't tax the computer.
    sam
    Quote Originally Posted by Zygoat View Post
  3. #39
    Feb 2010
    Quote Originally Posted by samco View Post
    sam
    do you have any links to such hardware?
    thanks for your help.
  4. #40
    Jul 2003
    Holmen, WI
    LinuxCNC Documentation Wiki: LinuxCNC Supported Hardware
    mesa and pico are probably the most popular. I am using mesa hardware and love it. Have a look at the 5i25 - it his mesa's latest pci card that has a bunch of options.
    sam
  • #41
    Registered Khalid's Avatar
    Apr 2006
    Pakistan
    This is the 2nd Part i machined out of SS316, 30mm thick plate.
    Used Facing, Profiling, engraving and drilling operation.
    I am getting gouging at smaller radius wall of the part.
    Thank You Zafar for converting this into CNC . I can easily get 0.5mm deep cut on SS316 but my spindle motor is week for more than 0.5mm cut.
    Here is the Video:
    "http://www.youtube.com/watch?v=wUttTrtwpvc&feature=g-upl&context=G2935e6bAUAAAAAAAAAA"]http://www.youtube.com/watch?v=wUttTrtwpvc&feature=g-upl&context=G2935e6bAUAAAAAAAAAA
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
  • #42
    Apr 2006
    Pakistan
    Some Pictures of the finished product:
    Attached Thumbnails Attached Thumbnails RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL-1.jpg   RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL-3.jpg   RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL-2.jpg
  • #43
    Feb 2007
    CUBA
    Hi Khalid
    Nice work!! Congratullations..
    By the way.
    I post you a PM.
    Could you help me?
    Regards
    Rene
  • #44
    Dec 2005
    Pakistan
    Wow, Khalid. You are already making parts on this mill. I thought you'll give it some break-in time. Did you do the engraving with the tool I made?
    For the spindle stalling problem, I guess you are using too low frequency for the motor. Using SS tools perhaps. I'd suggest using carbide tools and high rpm's above 1500 or so. You'll need good collets and holders too. I'll get some for you on my next visit.
    Zafar
    Quote Originally Posted by Khalid View Post
    Here is the Video:
  • #45
    Apr 2006
    Pakistan
    Quote Originally Posted by zafarsalam View Post
    Zafar
    Dear Zafar,
    Thanks for the suggestion about increasing RPM of Spindle Motor and use of Carbide tool. I did that engraving with your machined tool...I have got slight depth in consequent engraving and that might be due to spindle warming.. So we made a rule of thumb as to start Spindle and wait for 5 minutes before pressing the Cycle Start..
    I shall wait for the Collets and Holders and i hope you shall send us as early as possible as our TA of Plant begins from coming Monday so we need them most..
    I am getting some tool gouging marks at smaller radius walls.. Whereas The bigger radius seems smooth at the entire place, only a small gouging mark at tool entry location at bigger radius..I have to change entry /exit parameters outside the part to get smooth finish..
    Attached Thumbnails Attached Thumbnails RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL-gouging.jpg   RETROFIT OF RADIAL DRILL MACHINE INTO CNC MILL-2.jpg
  • #46
    Dec 2005
    To get rid of that gouge mark, try to use a lead-in, lead-out if you can. It creates a small radius at the end of the tool path. Lead-outs at the bottom of a part like that will need clearance, otherwise you'll crash the tool into the left over stock. You could also use a ramp, instead of many depth-of-cut passes.
    And I like that spindle light. Is it LED? I'm getting 2 of these: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices from China, and I hope they'll produce lots of light.
    Shaun
    my x2 conversion ------> http://www.cnczone.com/forums/showthread.php?t=36403
  • #47
    Dec 2005
    Pakistan
    Dear Zafar,
    Khalid,
    I would suggest using lead-in and lead-out to remove the gouge marks and also use rough and finish passes. I buy my tool holders and collets from KTD (PVT.) LIMITED you can contact them on the phone numbers at their website and inquire about the availability of ER40 collet holders and collets with MT5 shank. The ones I have are with BT40 shank. If you have adopters for BT40 then you can get these too. I'll be out of town this week. You can ask Mr. Nooruddin to buy the tool collets/holders for you and send them to you.
    The engraving tool cutting again on the same depth of cut is due to your tool runout. It is not producing a smooth cut so it appears that it is cutting again with subsequent cuts. I had noticed it when I tested your machine with that tool. A good collet holder will take care of that.
    Zafar
  • #48
    Apr 2006
    Pakistan
    Quote Originally Posted by skmetal7 View Post
    I used 3D Ramping for each passes for that part... but it is a good idea to use tangential lead-in and lead-out in my next oncoming part.....
    Yes this is 10Watt LED Light (220VAC) i purchased for 14 US Dollars in local store... The light is too bright and awesome...
  • Page 4 of 5 FirstFirst 12345 LastLast
    1. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
      By pfeist in forum General Metal Working Machines
      Last Post: 02-13-2012, 03:12 AM
    2. Anyone in the East Tennessee area doing a mill drill retrofit.....
      By pete from TN in forum Benchtop Machines
      Last Post: 05-04-2008, 09:00 AM
    3. Yoshida Radial Arm Drill Press
      By jnsane84 in forum General Metal Working Machines
      Last Post: 02-07-2008, 02:31 PM
    4. Where to begin? Retrofit a Stepper Control to a Mill-Drill?
      Last Post: 05-04-2004, 06:44 PM
    5. CNC retrofit for Mill/drill?
      By Jkier in forum General Metal Working Machines
      Last Post: 07-03-2003, 07:42 PM
