Results 1 to 6 of 6
Thread: Kolkmill
    Registered resuengineering's Avatar
    Nov 2007
    Netherlands
    Kolkmill
    This topic is about a milling machine build from scratch.
    i'm building with this machine allready for a while, but never set it online.
    so a long starting message
    First of all it's no wood the machine panels!!
    All panels have milled pins, and slots to make a tight fit, many M12 bolts and nuts are holding the panels together.
    - The machine slides are HiWin 15's,
    - all axis leadscrews
    - proximity switches for home sensing
    - Elte HF Spindle with ISO10 tools
    - Vacon HF VFO
    - USBCNC V4 interface
    - Advantronix board for tool change
    and many more nice things.
    Allready started with assembly of the electronic cabinet
    With 3 HP stepper drivers running at 75 Volt
    Some wiring
    Electronic cabinet outside.
    Currently the machine is running but not everything is ready and working
    here are some earlier movies of the machine
    [nomedia="http://www.youtube.com/watch?v=eLkxedZU8TQ"]YouTube- Elte HF Spindle test setup @ 40000 Rpm[/nomedia]
    First testrun of the Elte HF Spindle, 1,1kW max 40.000 RPM
    [nomedia="http://www.youtube.com/watch?v=KCwc7eUVUpY"]YouTube- Kolkmill ATC Solenoid testing / USBCNC / Advantronix testing[/nomedia]
    Indicator left up 5 Bar tool clamping
    Indicator left down 5 Bar tool unclamping
    Indicator right up 0,5 Bar bearing overpressure
    Indicator right down 5 Bar taper cleaning
    Used air valves are from SMC
    [nomedia="http://www.youtube.com/watch?v=r7VCHGJa5vY"]YouTube- Kolkmill ATC test[/nomedia]
    Slow testrun of the ATC
    [nomedia="http://www.youtube.com/watch?v=WTk7O3Q4t1g"]YouTube- ATC change Kolkmill[/nomedia]
    High speed testrun of the ATC
    The last movie is the current state of the machine.
    let me hear what you think about it
    Oct 2005
    That's a beautiful machine!
    Can you explain more about the wood construction, and any other machine details?
    Like pictures of the spindle and auto tool changer.
    Nov 2007
    Netherlands
    The Elte HF Spindle runs approx 40.000 RPM @ 633 Hz and has 1,1 kW power.
    has a pneumatic booster for tool change gripper. some more details on the site of ELTE
    Spindle gets driven by a Vacon Inverter, controlled true USBCNC
    Also a water chiller is used on this spindle.
    The Toolchanger is a home made changer.
    all parts are milled out of some solid pieces of plastics.
    here some detail pictures
    About the stucture of the frame i will take some pictures later on.
    the axis speeds are 7500mm....
    later some more details.....
    Nov 2007
    Netherlands
    Kolkmill cutting movie
    now time for real cutting....
    [nomedia="http://www.youtube.com/watch?v=rpX5hhG0mes"]YouTube- Kolkmill - Real cutting[/nomedia]
    Oct 2005
    netherlands
    Quote Originally Posted by resuengineering View Post
    Still amazing, woud love to see some alloy machining on it..!!
    Nov 2007
    Netherlands
    machine is at customer, he will cut woods and plastics with it.
    the next machine is in design progress, a 5 axis, self loading mill
  • Posting Permissions
