Old 05-11-2010, 09:51 PM
gumball is on a distinguished road
hwo to center a cylinder on my mill
I had to cut two shoulders on a vertical 1 inch piece of drill rod. I can find the y axis easy by using a wiggler on the vise jaws but the x axis stumped me.
I was using a big V block to hold the drill rod vertical, so I finally indexed off the edge of the V block. I worked OK but is there a easier and more accurate way?????
Old Bridgeport J head, with a 2 axis DRO, a 12 inch lathe, and assorted junk....
Old 05-11-2010, 10:20 PM
keebler303 is on a distinguished road
Once you find the Y axis center, you know the circle is biggest in X at the Center in Y. SO just put the Y axis on the center line and touch off both sides in X. Split that to find your center.
You can also use a test indicator in the spindle. The spindle is concentric with the shaft when the indicator needle doesn't move as the indicator is swept around the part. Basically the same as if you were centering on a bore.
Matt
Recommended center diameter for center rest CAMCRASH General Metalwork Discussion 2 03-30-2010 12:58 PM
Need Help!- turn mill center msantaji1 Haas Visual Quick Code 3 04-30-2009 11:33 AM
Just IN- CNC vert. mill and turning center looking for work OZZCAR Employment Opportunity 0 09-22-2008 03:09 PM
center drill diameter developpement on mazak nexus 640m mill Denis13 Mazak, Mitsubishi, Mazatrol 0 01-30-2008 08:56 PM
compressor piston cylinder compared to an IC engine piston cylinder CNCnUtZ I.C. Engines 1 12-28-2003 07:06 PM
