Old 05-09-2010, 11:06 PM
Ramu is on a distinguished road
How to machine Magnet
Hi
I have a round magnet black & want to resize it.
How do i machine it ?
I tried yesterday to turn it but the tool clings to
it.
Need Help
Ramu
Old 05-13-2010, 11:28 AM
jsheerin's Avatar
jsheerin is on a distinguished road
First demagnetize it. Then you would typically grind it using coolant. Remagnetize it when done (although depending on the type, this can be tough). I think you can also EDM neodymium magnets, but I'd recommend researching that before you try it.
Old 05-17-2010, 06:14 AM
SanDiegoCNC's Avatar
SanDiegoCNC has a little shameless behaviour in the past
Be aware... heat generated while machining this type of magnet will cause it to fail. I found that out the hard way several years ago machining a linear bearing assembly.
Old 05-17-2010, 09:55 AM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Diamond tools will easily cut ceramic magnets, beware that it makes are horrible mess though, and the sticky goo that's left wants to stick to everything...
I would suggest trying to find the right size magnet, or change the 'other' part, if it's to fit into something.
Paul
Old 05-17-2010, 10:11 AM
Gold Member
RomanLini is on a distinguished road
Cut it with a angle grinder and and thin (1mm) cutoff disc. A splash of water to keep it cool every few seconds and the angle grinder has enough RPM to throw off the bulk of particles (so they don't stick to the magnet). It will carve like butter.
The magnet trick; hardening steel rolfinator2002 Hand Tooling 1 03-15-2010 06:34 PM
Permenant Magnet Servos ozzie34231 General Electronics Discussion 6 03-26-2008 06:52 PM
Mad magnet hold-down idea martinw Mechanical Calculations/Engineering Design 20 01-18-2008 08:33 PM
Can use Permanent Magnet Synchronous Motor ? tivoidethuong Phase Converters and VFD 2 07-05-2007 09:10 PM
Gluing a magnet on PM motor? DennisCNC General Electronics Discussion 3 06-07-2006 08:09 PM
