Old 05-06-2010, 09:34 PM
vbbrett is on a distinguished road
Cheap CNC Mill for Gear-making
I'm looking to buy a cnc mill so that I can do large gears (6 inch diameter). Now, I have been looking at some options in the $4000, but I was wondering if something smaller would work?
More specifically, I've seen some small router/mills on eBay around $800 that say they work... not so sure! They do circuit boards. :-D
My question is, can a low-quality cheapo mill make a similar cut given enough time? (trading-in some inherent loss of accuracy)
More generally, what can I expect out of one of these cheap mills?
Thanks!
Brett
Old 05-06-2010, 10:34 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Brett,
What type of material would you like to CNC?
Welcome to the Zone,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 05-06-2010, 10:59 PM
I'm looking at aluminum or a standard grade steel. Nothing too special.
Thanks!
Old 05-06-2010, 11:43 PM
jalessi's Avatar
Post
Brett,
With a sparse amount of tooling and a rotary fourth axis capable of machining steel, you will be hard pressed to accomplish your goal for much less than $3,000.00
Jeff...
Making Gear cutters ozzie34231 General Metalwork Discussion 18 07-18-2009 11:21 PM
Making a four stage spur gear box? (how to ) youthreewire Mechanical Calculations/Engineering Design 14 02-26-2009 09:11 PM
What tools to use for Gear making? mooreaa General Metalwork Discussion 3 02-03-2008 08:25 PM
gear making tool or wizard of some sort Craigpat Solidworks 2 01-22-2008 12:39 AM
