Old 05-11-2005, 11:37 PM
cnc2k is on a distinguished road
Jig Saw
I want to cut some holes(4") on aluminum plate using a jig saw. is this a good idea?
Old 05-12-2005, 06:38 AM
Gold Member
InspirationTool is on a distinguished road
If eye-ball accuracy is all you need, and the aluminum isn't too thick (up to 1/2" shouldn't be a problem), or a wierd hard alloy, you'll be fine. Just make sure you are using a metal blade, and maybe add some oil or other lube.
My new makita jig saw just went through a 3/4" bar of aluminum last night, no problem.
-Jeff
Old 05-12-2005, 10:56 AM
rcazwillis is on a distinguished road
As Jeff stated, if precision is not an issue it works fine. I will however disagree with Jeff on one thing. Use a 6 or 8 tpi blade, not a metal blade. The aluminum will clog up the metal blade very quickly. The 6 or 8 tpi blade will stay clean and cut quickly.
Old 05-12-2005, 01:37 PM
Gold Member
Really? I'll give it a try this weekend. I assume I should use a "rip" tooth rather than a "crosscut" tooth?
Thanks!
-Jeff
Old 05-14-2005, 06:46 PM
Gold Member
I tried a more coarse blade.... seemed to work a little better, but it didn't seem night and day. I need to get some of those Bosch blades.
-Jeff
Old 05-14-2005, 10:34 PM
which jig saw do you have? I'm planning to buy the jig saw next week.
Old 05-15-2005, 01:29 AM
ger21's Avatar
Bosch makes the best jig saw I've ever used.
DIY Z axis 0 plate. It works perfect! balsaman DIY-CNC Router Table Machines 64 02-20-2010 11:52 PM
plasma water tank snaggletto CNC Plasma and Waterjet Machines 41 06-17-2006 08:04 AM
Edge finders and techniques. redbaron DIY-CNC Router Table Machines 12 01-04-2005 02:22 PM
welding jig georgebarr Welding, Brazing, Soldering, Sealing 2 05-23-2004 07:47 PM
paper jig David454 General CAM Discussion 4 04-18-2003 03:59 PM
