Old 05-03-2010, 11:37 PM
Alex K'eh is on a distinguished road
Mini lathe Hiccup
Hi guys, pretty new here so thanks for reading this...
I bought a craftex 4 x 7 metal lathe and believe it or not after using it for only three months I got a chirp...yep every revolultion brings that tell-tale chirp that let's you know something is thrown off centre.
I can't get a centre tap anymore and I'm definitely getting inconsistencies with facing material.
I only run solid C1018 steel and C360 brass at 3/8" so I know it isn't the material overdoing it.
The question is where would you suggest I start looking to solve the problem. I'm pretty new to machining but I have no problem with taking it all apart and putting back together. Logically I think the axle is off but before I do anything i figured maybe all you machining meisters might have a better start point (before i do too much...know what I mean).
Thanks all! Alex
Old 05-05-2010, 02:21 PM
EPTech's Avatar
EPTech is on a distinguished road
Since you get inconsistencies in facing, the only think I can think of is that you got play on the X-axis slideway. In most cases those slideways can be adjusted with allan bolts. Simply tighten the bolts so that you can still confortably move the carriage but with as little play as possible. You have to check the Z-carriage also and the cutter support carriage. In fact, check everything for play.
greetings.
Old 05-05-2010, 06:12 PM
Thanks for the starting point amigo...I'm going to start on that some evening this week...I'll post my progress...cheers!
Mini lathe and mini mill spindle? ZipSnipe General Metal Working Machines 3 10-15-2010 08:13 AM
Problem- Auto Tool Zero Hiccup? mcyr Mach Mill 3 08-23-2010 01:25 PM
New Machine Build- My CNC mill with mini lathe performing CNC lathe operations ryansuperbee General Metal Working Machines 7 08-20-2008 01:06 AM
X2 Mini Mill & Mini Lathe - Cummins Tools ccsparky Benchtop Machines 0 12-19-2007 07:54 AM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 08:36 PM
