Old 04-27-2010, 04:24 AM
maltria is on a distinguished road
Help please... setting a part in a Lathe :(
I have a Herbert HC2/10 cnc lathe using Fanuc 6T software, it works a treat, having been owned by an ex millwright
However I am led to understand that a cnc lathe (this is my first) has 3 coordinate settings...
1) for the tool
2) for the chuck
3) fo rthe part "0" point, in my case the furthest dimension (end of work) from the chuck.
I just don't quite understand how I can tell the control where it is
Regards Martin
Old 04-30-2010, 04:41 AM
fomaz is on a distinguished road
Do you have a work setting? Normally under offset/setting?
Did you already made the tools offsets?
Post more info,please.
Newbie- part setting issues. autobionics Bridgeport and Hardinge Mills 6 06-13-2009 03:54 PM
Problem- Z zero setting on lathe pareicher General Metalwork Discussion 6 04-16-2009 01:35 PM
Setting up my new Microlux lathe... Nelson_2008 Mini Lathe 0 03-02-2009 01:16 PM
Help with setting up this part skipper SolidCam 6 06-17-2008 02:17 AM
Setting up job as mill or lathe? Art Ransom Machines running Mach Software 0 10-20-2006 06:38 PM
