Old 04-26-2010, 07:14 PM
keen is on a distinguished road
New type of machine tool
Greetings.
I have invented and developed a new type of internal and external portable screw thread cutting machine. I am doing some research to see what its market potential is. I attach some jpg's and a Youtube link:
YouTube- Thread cutting machine
Let me know if you are interested.
ID:	105970   Click image for larger version
Name:	int and external.jpg‎
ID:	105972   Click image for larger version
Name:	small samples.jpg‎
Old 04-27-2010, 04:15 AM
maltria is on a distinguished road
Looks simple, cheap and effective all the ingredients to make it successful.....
How about adaprting it to take off the shelf thread milling cutters ?
Old 04-27-2010, 06:18 AM
crazyau is on a distinguished road
Looks great! How does it go with stainless and other "fun" material?
As for your best option - I guess it depends how much work/ money you want to put into it!!
Good luck
Old 04-27-2010, 08:13 AM
chich2 is on a distinguished road
Nice machine! With another automated axis it could do tapered pipe threads too.
Great to see someone having a go.
Hope it works out well for your new invention.
Chich
Old 04-27-2010, 08:34 AM
Could simply rotate the headstock around the vertical axis .... like offsetting the tailstock
Old 04-27-2010, 10:25 AM
rowbare is on a distinguished road
I like it. It is a nice adaptation of thread milling.
bob
Old 04-27-2010, 03:17 PM
Thanks guys. I need lots of feedback before I can be sure of the best road forward.
Here is more info - and it should answer your stainless question . I paste below a blurb I have prepared.
Machining of Screw Threads
In order to put Threadexpress in its context I present a little background. It has struck me for many years that screw thread cutting is a relatively poorly developed process that poses many problems for service engineering companys, mechanics, machinists and DI Y ers etc compared with other machining/engineering processes. Ask a machinist to read the following and he will certainly concur:
Taps,dies, chasers etc are convenient but only give average results and large diameters and tough materials test their inherent limitations. Of course an additional problem is the almost limitless range of tooling needed for all the thread pitches and diameters.
Manual Lathe screwcutting Gets around the need for these tools, but presents its own limitations. A lathe needs a large range changeable ratio gearbox to supply the many different required ratios between the lathe spindle and leadscrew . This makes it complex,heavy and expensive (or it has a limited range). Screw cutting on a lathe requires advanced training and good aptitude to overcome the inherent limitations of this machining process. If one sets the speeds and feeds at optimum, the tool is in contact with the chuck before you can blink.
If one sets them at safe settings, repeat cuts tear and highly load the tool and work, and a tidy run out each time is difficult. The run-out area puts loads on the tool tip that are erratic and mean new generation carbides etc are likely to chip.
CNC mills and lathes Overcome a lot of the above issues however the average mechanic,machinist or DIY usually cannot afford the capital cost or steep and long learning curve of CAM/CNC.
Threadmilling It just so happened that my background as toolmaker/machinist caused me to repeatedly run up against the above problems. I needed to produce accurate threads with a neat run out for Plastic Injection Mold unscrewing cores, and later on again needed to machine tough stainless steel special fasteners for highly stressed high pressure pumps. This caused me to study and develop thread milling, in the form of thread milling attachments for my lathes. It soon became clear to me that this machining process overcame many of the inherent difficulties above. The cutter could be carbide and run at high speeds, the work could be turned slowly – even by hand, and one or two cuts only were needed. The best part was the run outs were safe and clean and the finish high.
There were obviously sound principles at play here.
Threadexpress While doing this work it was clear to me that the machining loads were remarkably light. I began to think that the potential of this already established process was not being fully capitalized on. If the cutting loads were so light that the the chuck could safely be turned by hand – and the work and cutter spindle could be so slender and yet not generate much chatter, why couldn't a light and simple, even portable, new type of machine tool be produced.......
Of course the reason was that a complex and expensive gearbox would be needed for all the different pitches.....So there it sat for several years.
One day a mechanic friend wanted some special studs screw cut for his rally car urgently. And yet again it struck me. This is crazy, why does it so often have to be such an issue for all of us hands on people, to get good threads cut ? That day I came up with a radical idea.
A light and simple pitch generating new technology that allows a limitless range of pitches and diameters to be quickly set and cut. I did the calcs and research, It seemed too simple and too bizarre to work. I developed the design more fully and slowly began to believe it just might work. I then began to search invention data bases for any other inventor that might have invented it also - (but who had obviously failed to capitalize on it). Over*many hours*over many days I viewed*scores of inventions, all far more complex or difficult to manufacture, and found nothing the same.
I then began the construction of the prototype.*I decided this prototype should not just test the unusual operating principle, but also test how it would work in practice as a lightweight or even portable machine tool.*I spent many hours refining the design and building a 'semi production' prototype. I cut unimportant corners where we could, but put the time into refining the design and construction of the key areas.
The operating principle worked so well, that even in its preliminary thrown together stage, it was very promising. I further refined the machine and tried it on a tough high tensile steel M12 bolt. I*know from many years of hands on design, toolmaking and machining experience the difference between a marginally functioning design, and a machine that just 'wants to work' This is one of those. See actual part JPEG at the start of my thread. Try doing that with a dienut or on a lathe – let alone a light weight portable machine!
Thanks for wading through all that!
Old 04-27-2010, 03:27 PM
Hi maltria
Re: How about adaprting it to take off the shelf thread milling cutters ?[/QUOTE]
Yes, the current cutter setup is just for the prototype. It would probably suit a budget DIYer.
A collet type cutter holder would allow using off the shelf thread milling cutters and have some advantages.
Old 04-27-2010, 03:32 PM
Hi again maltria
Re taper threads:
Could simply rotate the headstock around the vertical axis .... like offsetting the tailstock [/QUOTE]
Thats what I have been thinking also, It would add a little to the cost.
Feedback on desire for this feature appreciated!
Old 04-27-2010, 06:13 PM
307startup is on a distinguished road
I like it
  #11   Ban this user!
Old 04-28-2010, 03:02 AM
jatt is on a distinguished road
RE: the questions at the end of the vid.
How much work do you want to do?
If you can find someone to buy the idea outright or pay royalties then that is obviously the easiest for yourself. If it was me in this instance would try for having it purchasing it outright, before the likes of the Chinese got onto it and started churning them out. Seems to me they have no regard for US style patent laws.
Selling the plans: not a bad idea. Plenty of others out there doing that with their respective gadgets. Making some parts yourself for sale upon request.
Idea looks to be a goer. Good luck with it.
Part time fabricator
  #12   Ban this user!
Old 04-28-2010, 02:55 PM
[QUOTE=jatt;768568]RE: the questions at the end of the vid.
How much work do you want to do?"
Hi Jatt - I suppose I need feedback/ market information before I decide which option forward is best. I dont mind work, as long as it is productive. What option do you guys prefer?
If its buying the plans - would you buy them? How much do you think would be a fair price? .... etc... etc
What Type Cutting Tool to Mill SST ? Aaron 1874 General Metalwork Discussion 4 07-25-2010 03:00 PM
Need Help!- What type of tool holder is this??? Michael Turner CNC Tooling 12 11-09-2009 09:24 AM
Need Help!- Material need for insert type tool holders ARIF AHMED General Material Machining Solutions 4 11-02-2008 01:34 PM
Which tool bit type for surfacing aluminum with a fly cutter? cnczoner General Metalwork Discussion 5 01-03-2008 01:54 PM
Bed type tool changer gcoding Mechanical Calculations/Engineering Design 1 06-06-2006 07:37 AM
