Old 04-25-2010, 01:22 PM
Dave2962 is on a distinguished road
Lodge and Shipley lathe problem
I just bought a Lodge and Shipley RXE-2518 lathe. I just got it wired up and the spindle sounds great, but I can't get the lead screw working. None of the feed gearing is turning. I don't know if I just don't have something engaged or if there is a problem. Does anybody have any experience with these lathes?
Dave
Old 04-25-2010, 01:28 PM
KKutt is on a distinguished road
There is usually a lever on the headstock to engage the lead screw so it is not always turning, if that is not the case you might look under the end headstock cover to see if the feed drive gears have been removed.
Milling on lathe problem Kalasmannen Daewoo/Doosan 2 02-09-2010 08:11 AM
Lodge and Shipley H-8 Info needed gschoep Index CNC lathe 0 09-17-2009 10:41 PM
Bridgeport/Adcock&shipley 1S Schematic/Diagram T_Rex Bridgeport and Hardinge Mills 0 12-23-2008 03:48 AM
Mastercam Lathe V9 Problem jjwl89 Mastercam 3 03-23-2007 02:54 AM
