Old 04-22-2010, 10:40 PM
ranchak is on a distinguished road
Automatic Downfeed on a Surface Grinder?
I have a Harig 618 Automatic grinder that I would like to have an automatic power downfeed on. Is there a kit to add this feature? I searched the web for a DIY or Homebrew idea, but couldn't find anything. Seems like a stepper motor and some small control circuit could be used. Any ideas?
Old 04-28-2010, 03:17 PM
metalworkz's Avatar
metalworkz is on a distinguished road
Hello Ron,
I wonder if you could remove the downfeed handle and attach a stepper to that shaft and possibly use Mach3 to control the downfeed in the required increments?
Seems you could use it like a Z axis and set the toolpath up so that when the surface has been cleared it would feed the Z down and feed back across the surface for the next pass...? I saw that Harig has an Autostep model that looks like the downfeed is programmable but did not see any mention of an add on from them.
Regards,
Wes
Regards,
Wes
Cnc surface grinder for profiling Mike Wood General Metal Working Machines 1 04-19-2010 11:06 AM
Problem- Unknown surface grinder in need of tlc jacek General Metal Working Machines 3 04-12-2008 12:38 AM
Surface grinder improvement caliper General Metalwork Discussion 10 12-02-2007 12:40 PM
Surface Grinder gbowne1 General Metal Working Machines 12 02-27-2007 11:28 PM
Surface Grinder itsme General Metal Working Machines 18 09-13-2006 12:28 AM
