Old 04-21-2010, 06:45 PM
rppman is on a distinguished road
power for coolant pump....
I have a three phase 1/8 hp .6 amp coolant pump on my new machine and my question is, can I use a 3hp static phase converter to run the small pump? I already have the converter and I am not using it since I got my VFD spindle drive. The pump should only draw what it needs correct? Thanks for any help. Scott
Old 04-23-2010, 05:19 AM
Anyone? Don't be shy now...
Old 04-23-2010, 08:34 AM
Al_The_Man's Avatar
Shouldn't be a problem, maybe a bit of overkill if the P.C. is large capacity.
Old 04-23-2010, 09:17 AM
Thanks Al, I had thought about wiring it in with my T1, T2, and T3 off of my spindle inverter but I didn't want to take any chances. It would have been nice in some aspects such as not needing a coolant contacter but the other down fall would be that some jobs I might not want coolant .
Old 04-27-2010, 09:55 AM
henry_L is on a distinguished road
i suggest that you set the max.current of the moter in the invertor.otherwise the motor maybe fire if it overload
Old 04-27-2010, 11:56 AM
I think I am going to just use the static phase converter even tthough it is a bit overkill. I do have a overload circuit that is conneted to the contactor that is set to trip at around .7 amps.
Old 04-30-2010, 03:36 AM
OK,i guess that your overload protective circuit is overheat protective under the contactor of the motor.
that is also a good mothed.
i'm very interesed in the manchine and this en form .but my english is very poor .so i only read posts most time
325 Coolant Pump TurtleRacing Tree 4 04-02-2012 01:51 PM
Tm Coolant Pump behindpropeller Haas Mills 1 03-15-2010 10:45 AM
Need Help!- coolant pump JACKSMACHINE Fadal 0 05-22-2008 03:13 PM
TM2 Coolant pump Peter Gibbs Haas Mills 4 05-03-2008 12:11 PM
Coolant Pump Smackre Mechanical Calculations/Engineering Design 7 06-29-2007 01:16 PM
