Old 04-20-2010, 10:34 PM
ranchak is on a distinguished road
Harig Won't Reverse
I just bought a Harig 618 Automatic Surface Grinder. The problem I am having is that the longitudinal table will not reverse. I have tried manually moving the table reversing lever and nothing happens. Is it possible that the reversing valve is 90' or 180' off? I am running this grinder on a VFD, the VFD will shut off due to what I think is overpressure from the hydraulic pump. The grinder was recently moved before I bought it. Any thoughts?
Bridgeport Harig EzSurf NC Cams Bridgeport and Hardinge Mills 11 08-30-2011 12:27 PM
Bridgeport-Harig 618 Ez-surf user manual needed simonr8126 Bridgeport and Hardinge Mills 3 04-18-2010 02:44 PM
Reverse Whacko LinuxCNC (formerly EMC2) 23 12-15-2008 08:31 AM
reverse x + and - jybute Haas Mills 8 06-03-2008 12:13 PM
Need Help!- Bp Harig Ez-Surf grinder manual jketcham Bridgeport and Hardinge Mills 2 05-11-2008 04:42 PM
