Old 04-16-2010, 10:11 AM
Rich 72 is on a distinguished road
Wasino lathe ball screw
I've got a late 90's Wasino LG-7 and am noticing the X axis is very sloppy. I know you can adjust for backlash in the CNC parameters but this seems really bad. Other that replacing the ball screw is there any way to tighten this to remove some of the end play?
Rich
Old 04-16-2010, 10:23 AM
Is it possible the end play is in the support bearing assembly (bearing slop, brackets holding the bearing, attachment points of the bearing housing)?
Dick Z
DZASTR
Old 04-16-2010, 10:41 AM
Yes I suppose it could be that. I just noticed a lot of movement in that axis and was looking for some ideas on what I should be looking for
9 X 20 Lathe Z travel Ball Screw Me2 Mini Lathe 1 05-24-2009 05:34 AM
Need Help!- Wasino gang tool lathe W/3T control kz1670 Fanuc 0 10-16-2008 11:06 PM
lathe turning a ball screw end margni74 General Metalwork Discussion 14 12-04-2007 09:57 PM
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
