Old 04-16-2010, 03:12 AM
Spindle_Boy is on a distinguished road
Scribing Diffraction grating with 5 axis CNC
We have a brand new Spinner 5 axis MC 650 here in Maui. My boss wants to try scratching a linear diffraction grating 5mm10mm(10 micrometers deep and 20 micrometers spacing) onto aluminum with a random "sharp" tungsten carbide tip we found in our machine shop. The problem is they want to do this with the spindle off!! I am against this as the tip geometry is not capable of generating this, not to mention the best I can measure the tool and work offset at the moment is ~.2mm I am worried about the spindle bearings, spindle skipping a tooth.
Any other reasons it's a bad idea?
I want to try an endmill with the working plane at 45 degrees and the spindle on.
has any one ever done anything like this ?
The positioning accuracy of the linear axes is +/- 2 micrometers so in theory we should be able to fabricate some kind of IR grating.
Old 04-16-2010, 09:43 AM
CalG is on a distinguished road
Don't use the spindle (though I doubt you could hurt it scratching out a grating in any material. The machine would just flex before any bearing damage would take place)
Just clamp the "tool" to any stationary point relative to the moving table.
Tags
diffraction grating, engraving, grating, scribing
Inventor & EdgeCAM scribing text 80083r EdgeCam 9 03-10-2010 10:52 AM
Scaling and Rotation for scribing rs7769 Fanuc 3 12-09-2009 11:19 AM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
