Old 04-14-2010, 07:35 AM
will gilmore is on a distinguished road
Lathe gang tooling and dowel pin questions
I'm building a small gang tooled lathe. Here is the full build thread: http://cnczone.com/forums/showthread.php?t=92337
I'm ready to figure out how to attach the tooling to the tooling plate.
My thoughts so far are to use two dowel pins and one bolt for each tool holder. o=hole for dowel pin, x=threaded hole for bolt
o x o
o x o
o x o
o x o
o x o
If I can do this accurately I can drop tools on and have them be accurately located in X and Z. Open to suggestions.
I've never used dowel pins before. Tooling plate is ground O1 tool steel. Here is my plan so far. Spot drill, drill with C drill (.242"), ream with .251" reamer. Open to suggestions.
Thanks, --Will
Old 04-14-2010, 09:55 AM
beege's Avatar
beege is on a distinguished road
I'd use locating pins like this. A little more forgiving than two dowel pin locators.
Old 04-14-2010, 10:48 AM
I get the redundent locating idea. Could I get away with grinding some flats on a dowel pin instead of paying for a fancy locating pin?
Need Help!- Gang tooling help.. roger_e Vertical Mill, Lathe Project Log 0 01-29-2010 06:03 PM
School TL-1 and gang tooling TEntpeg Haas Lathes 15 12-13-2009 03:04 PM
Gang tooling lcarrudajr TurboCNC 1 05-08-2009 04:47 PM
Gang tooling vs turret baldysm General Metal Working Machines 3 12-03-2007 04:47 PM
Gang tooling vs turret baldysm CNC Tooling 1 11-28-2007 11:03 PM
