Old 04-12-2010, 09:16 PM
diyengineer's Avatar
diyengineer is on a distinguished road
Talking 15' long 8' wide Ex-Boeing CNC *REBUILD*
PICTURES & specs will be uploaded tonight!
Purchased last Tuesday, want it up and running by the end of summer.
Main intent purpose, Cutting aluminum sheet (.063").
I will need everyones guidance and 2 cents on this rebuild! Should make for a awesome summer project!
-Thanks
Old 04-12-2010, 09:23 PM
Al_The_Man's Avatar
Did you find out what motors are on there?
Old 04-12-2010, 09:33 PM
advt001 is on a distinguished road
Diy did you stop on your other project?
Old 04-13-2010, 07:49 PM
The other project is 99% done engineering wise in solidworks. Just needed to make spacers that harness the ballnuts to the table to transfer motion, which takes 2 seconds. This deal was to good to pass up, so my funds and time are now 100% on this.
Old 04-13-2010, 07:55 PM
Have not taken the servo plates off yet, just finished cleaning the entire machine, gutting the old wires and vacuum hoses, and cleaning, cleaning, cleaning lol. Oh and it took me a few days because i citric acid bathed 14 individual linear rails. They turned out PERFECT
Old 04-13-2010, 08:10 PM
These are the current pictures, after i cleaned the entire machine, gutted out the old vacuum hoses, and all of the old electrical wire. I took off 14 linear rails, 7 on each side and acid bathed them for 24 hours. The results were amazing! I will submit a before and after picture in my next post.
I currently need to dig into the gantry. In "Image 9275", The 2 aluminum plates each house a servo on the other side. The left servo connects to the ballscrew via a belt and the right servo connects to the very large black gear which is connnected to a toothed pinion gear that meshes with the linear rails. If you look even closer there are two very large black flat headed screws on the left and the far right. each houses a bearing, one above the linear rail, and one below the rail. The unit has an addition bearing which is in clear plain site (in front of the black gear, below the large gold gear).
My plan is to take out the ballscrew, citric acid bath it for 24 hours to remove all surface rust, re-oil. If possible purchase all new bearings for the ball screw along with the ones behind the black screws and in plain sight. replace and and all old hardware/parts and citric acid bath whatever i come across that needs it. Then repaint entire gantry (since it will be in pieces anyways).
Question though, if i remove the ballscrew and i take the "Ballnut" off will all the ball bearings come spilling out, or are they locked in there?
ID:	105131   Click image for larger version
ID:	105132   Click image for larger version
ID:	105133   Click image for larger version
ID:	105135   Click image for larger version
ID:	105136   Click image for larger version
ID:	105137   Click image for larger version
ID:	105139   Click image for larger version
ID:	105140   Click image for larger version
ID:	105141   Click image for larger version
Old 04-13-2010, 08:33 PM
Here is a few pictures before the machine was cleaned, rails acid bathed, and new rail hardware installed (84 bolts).
Monster rust.
ID:	105145   Click image for larger version
ID:	105146   Click image for larger version
ID:	105147   Click image for larger version
ID:	105149   Click image for larger version
ID:	105150   Click image for larger version
ID:	105151   Click image for larger version
ID:	105153   Click image for larger version
ID:	105154   Click image for larger version
ID:	105155   Click image for larger version
ID:	105157   Click image for larger version
ID:	105158   Click image for larger version
ID:	105159   Click image for larger version
ID:	105161   Click image for larger version
ID:	105162   Click image for larger version
ID:	105163   Click image for larger version
Old 04-13-2010, 08:39 PM
Bathed them all for 24 hours in a 35 gallon commercial grade plastic trash can. I used 5 pounds of organic citric acid (100% edible) + hot tap water. Wire brushed once after 12 hours, and once again at the 24 hour mark. Towel dried them off, then used compressed air to blow them off, then used a propane torch to 100% dry them. Then applied machine oil to them.
ID:	105166   Click image for larger version
ID:	105167   Click image for larger version
ID:	105168   Click image for larger version
ID:	105170   Click image for larger version
ID:	105171   Click image for larger version
ID:	105172   Click image for larger version
ID:	105174   Click image for larger version
ID:	105175   Click image for larger version
ID:	105176   Click image for larger version
Old 04-13-2010, 09:09 PM
DIYaholic's Avatar
DIYaholic is on a distinguished road
Question
diyengineer,
Some of the surfaces look "discolored", is this a surface staining or is there any pitting? Results look impresive though.
Keep the pictures coming!
Randy,
I may not be good....
But I am S L O W!!
Old 04-13-2010, 09:18 PM
Originally Posted by DIYaholic View Post
diyengineer,
Randy,
The citric acid bath is clear, but when exposed to oxidized metal like rust it turns BRIGHT NEON YELLOW. The bath leaves a hue of yellow on the surface, almost like a light anodized sort of look.
There are some other discolored spots but there is no surface damage at all (pitting), i think its just where the rust left a weird visual stain effect. Pretty impressive results considering the citric acid is 100% organic and edible haha! It cost me about $20 dollars buying it in bulk from the local heath food store.
If all else goes well i will probably break down and pay to get them hard chrome plated or professionally anodized in the future.
Old 04-13-2010, 09:25 PM
Al_The_Man's Avatar
They will come out if you wind the nut off, the tubes you see are reloading tubes, it looks like someone has taped them.
Carefully save the balls if you take them apart, there may be two sizes that are fed in alternatively when you reload the nut.
Or order new ones if they are pitted.
  #12   Ban this user!
Old 04-13-2010, 10:53 PM
YouTube- CNC Rebuild Video #1
Just uploaded this to youtube, view in 720P for a better picture.
Thought i would try my Flip UltraHd camera out cause its so small and easy to upload to youtube.
Anyways maybe someone can help me out with ideas on how to get that gear off.
*forgot to mention, the large black gear is not metal, its some sort of ABS like plastic*
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Need Help!- slotting 4130 .07 wide .25 deep 8inches long ryanschmidt224 General Metalwork Discussion 6 08-08-2009 09:40 AM
Just IN- WARDJet Partners with the University of Sheffield AMRC with Boeing WARDJet-Ken Product Announcements & Manufacturer News 0 03-24-2009 03:17 PM
Boeing and Siemens PLM Software Mike Stevenson UG NX 0 08-02-2008 01:09 AM
Boeing 777 MOOG B-22 Hobby Discussion 8 07-09-2007 11:44 PM
Boeing 777 MOOG B-22 Jet Engines and Ram Jets 1 07-09-2007 03:30 PM
