Old 04-07-2010, 09:25 AM
cnczoner is on a distinguished road
Question for anyone using a Microkinetics CNC machine
For anyone using a Microkinetics CNC machine, I'd appreciate hearing your thoughts on their CNC controller. Specifically, their MN400 motion controller, which I'm looking into for a multi-axis machine I'm building.
My two current concerns are that (1) I have concerns about them as a company, and (2) someone posted that the processor takes considerable time to calculate each move, so there are a lot of pauses between moves. I expect a motion controller to optimize the motion for best acceleration, speed, etc, so pauses contradict that.
Would appreciate any info, thanks.
Old 04-09-2010, 08:32 PM
No one here at all using these? Wow, I would've thought they'd be a bit more popular, but perhaps this is my answer.
Old 04-09-2010, 11:58 PM
GeneK is on a distinguished road
microkinetics
Someone on one of the Yahoo Sherline groups just revived a microkinetics based Sherline mill and lathe. He got it working with Mach 3. He has posted the pin outs in the file section.
If you're interested I'll look for his contact info.
GeneK
Old 04-14-2010, 02:43 AM
jonathanm is on a distinguished road
I'm interested in who he is, I'm in the same boat. I just got hold of a microkinetics sherline mill, with stepper driver box but no motion controller. I've got it working with mach 3 also, though not optimally yet.
Old 04-14-2010, 10:04 AM
Gene, that would be nice, thanks.
Old 04-14-2010, 03:19 PM
Micro Kinetics
His name is Ron Croonenberg, he's on the SherlineCNC yahoo group.
I don't seem to find his actual e-mail address. but you should be able to find him through that list.
GeneK
Old 04-21-2010, 11:31 AM
TitaniumCannons is on a distinguished road
My thought of microkinetics MN400 don't buy it read
This MicroKinetics CNC Lathe I had purchased used that was only 1 ½ years old that had had only a few hours on it has got to be the biggest mistake I have ever made.
It’s absolutely a piece if you know what. I had finely got a job to drill 200 aluminum parts in 2.5 Dia by 3.5 long and face both sides I had set the start position. and several times so far after doing only 60 or so parts I had to change both the Z & X setting on the code by close to 0.030 plus or minus in either direction. And now I have to reset the start position because the X axis messed up again and kept going after it was suppose to stop and ruin the part and I had to use the emergency stop.
This machine was a problem from the start because the encoder and the drive rack times out I had paid for tech support and could get nowhere at all unless I paid extra and shipped it back and at this point I had already had close to 8 grand into this machine with the tooling I had bought. So I had requested a refund on the support and received it so that was good.
If your making wood parts this machine may be good for you I’ll have it for sale here soon I’m really sick of this piece of you know what.
Or my other option is to re retrofit it to a better controller and run mach 3 so if any of you out their have a good controller and software let me know this machine’s controller could never do any precise work such as ball mold cavities where tolerance’s are important I find it really hard to believe that this CNC lathe made the parts that are on their webpage. The videos that they show are of simple turning and I can’t even imagine this lathe doing internal threading or even external.
And yes I had checked all the bolts on the ball screws for back lash and that also brings up the other issue I had before on the Z axis and the locking collar that had kept moving whenever I had used the rapid transverse move that had happened several time I don’t even use the G00 code in fear of that happening again and yes the set screw is tight. In my opinion they should use a torque coupling for the axis.
This machine is a poorly designed and I would not recommend it. It’s a piece of you know what I could be doing these parts instead of complaining about it so far it’s taken 2 days to do 60 parts face both sides chamfer the edge and drill a hole in the center.
Also the Turn Master pro program is junk the wizard program will take a wizard to make it work such as the threading option what a nightmare I’m SICK SICK SICK Of this Unit. If you purchases this and have the same issues leave a post here but don’t say I didn’t warn you. Also please let me know if you know where I can purchases a retro fit kit the lathe its self is somewhat reliable.
Thanks Austin
www.ClassicCannons.com
Old 05-04-2010, 02:42 AM
GeneK
whoops, I missed this somehow..thanks for the info
Old 05-04-2010, 02:50 AM
Thanks Austin
Austin, I have found with mine (I've got a mill not a lathe) that I could run the stepper drives directly from Mach3 via the parallel port.
Calling out to anyone who has a Microkinetics GTS CNC Milling Machine PHSS General Metal Working Machines 0 04-02-2010 11:25 PM
Microkinetics steper motor question big iron General Electronics Discussion 1 12-30-2009 02:39 PM
Microkinetics Postprocessors got_woody Post Processor Files 6 07-23-2007 09:28 AM
MicroKinetics Lathe Doughty CNCzone Club House 0 06-25-2006 11:14 AM
MicroKinetics mbam Stepper Motors and Drives 1 06-06-2005 05:19 PM
