Old 04-05-2010, 04:59 PM
Thorpydo is on a distinguished road
Low budge CNC Lathe options?
I'm interested in purchasing a CNC lathe.
My budget is under $6,000. I'm looking for something that can hold a +/- .0005 tolerance, that is rigid enough to cut steel and that can make use of multiple tools without operator intervention, so I guess probably gang tooling or a turret.
Are there any lathes on the market that will suit my needs?
Thanks,
Adam
Old 04-05-2010, 05:18 PM
keebler303 is on a distinguished road
Used machinery? Lots of it available right now.
Matt
Old 04-05-2010, 07:06 PM
CNCRim's Avatar
The chance find cnc with that budget is slim, but possible.
Old 04-07-2010, 09:56 AM
cnczoner is on a distinguished road
I was looking for the same thing, and could find many used machines in that price range, but they were older machines which means questionable reliability, and also very very bulky.
I ended up deciding to convert my own and got a Grizzly G0602, estimating about $2k to $2.5K total without the controller (as I will use the same controller that runs my CNC mill. But alas, I have not had the time -- last month I finally got it out of the crate and set it up -- that's 14 months after I purchased it. Now, I just have to find the time to convert it. If you have the time, it may be the way to go, and I know a couple others have done this, with info posted here on the zone.
Cheers,
-Neil.
Old 04-07-2010, 10:42 AM
fastlanecafe is on a distinguished road
Originally Posted by Thorpydo View Post
Thanks,
Adam
Your budget is pretty small for what you are asking ( couldn't even afford the " T " in budget)- seriously, when you add zeros behind the decimal point under accuracy, you end up adding zeroes to your price tag.
For what you are looking for, you would have to buy a used production machine and hope its not too worn out. Converting a new lathe eans you will start out with some sort of Chinese machine and will probably not end up with the precision you want. 0.005" would be reasonable. Your multiple tool changer busts your budget for any new machine.
Old 04-07-2010, 11:04 AM
You forgot a few things. What size workpieces? Weight? Power required to efficiently process workpiece? etc.
Dick Z
DZASTR
Lathe Variable Spindle motor options? VFD? Servo? Stepper? DC? whiteriver General Electronics Discussion 21 03-16-2011 07:38 PM
looking for options chunkymonkey CNC Swiss Screw Machines 3 07-16-2009 10:21 AM
DRO options befunovo Industrial Hobbies (Support forum) 2 12-23-2008 08:04 PM
X2 Options wocowski Benchtop Machines 12 11-25-2007 07:31 PM
To many options dalescnc PicStep Controllers 1 08-04-2007 09:12 AM
