Old 04-03-2010, 11:57 AM
Ark1 is on a distinguished road
Coolant for Milling Machine.
I have a few questions about coolant for my Milling machine.
Currently I have been using soluable Oil with water.
Years ago I worked installing an electrical supply feeder for a large Cinci Milicron machine at Menasco ( now Goodrich ) areo space and noticed that the coolant was changed on a weekly basis and an outside contractor came in every two weeks to recondition the coolant/ cutting oils.
What is the prefered coolant for flood type coolant systems. It has been years since I changed the coolant and it has become rancid, with algee on the surface of the tank. Just an awful job to clean and remove.
What is recomended? Oil type, inveral.
My machine sits alot for months between uses. Could use some direction?
Thanks.
TonyK.
Old 04-05-2010, 10:23 AM
78nova is on a distinguished road
Talking Coolant
I am not sure why you picked the coolant you have in the first place but let me tell you what I have experience with.
We use Mobil Omnicrom oil for coolant. It is like a 30 weight oil. We use this in most of our machines that are cutting aluminum.
We use Hangstefers Hard Cut 5418 oil for cutting steel.
We do have a few machines that use water soluable fluid called Trimsol.
Any water based coolant will need periodic maintenance where oil with filters should last for a year at least.
I have a friend in Brazil who was using soluable oil with water and it was working OK for most of his parts but when he started doing aluminum manifolds it was not working on the form tools / gun reamers being used. The coolant he was using did not have enough lubricity and the 32 finish requirement was being exceeded and it left the tools and parts black.
He switched over to oil and this solved the finish problem.
Hope this helps you.
Have a great day.
Coolant for milling aluminum rchunter94 General Metalwork Discussion 1 03-03-2008 03:04 PM
SS 304 sheets milling dry or with fluid coolant mist Vincent82 General Metalwork Discussion 3 11-17-2007 10:40 PM
what coolant to use when milling copper?(3d design inside) HawainPand General Metalwork Discussion 14 04-18-2007 09:51 AM
Milling coolant needed bob1112 General Metalwork Discussion 9 04-09-2007 06:32 PM
milling aluminium without coolant ? andy55 General Metalwork Discussion 6 10-19-2005 08:00 AM
