Old 05-02-2005, 10:52 PM
ozzie34231 is on a distinguished road
Question Lathe Tool Posts
Hi All,
I'm cosidering buying a quick change tool post, something along the lines of the Phase II series.
I bought the Shoptask compound tool rest and the accompanying tool post and it's a joke; no stability at all. Even with the moderate cuts I make, the tool is likely to move no matter how tight I try to make it. With CNC there's little reason for the compound anyway.
I'm not sure I know the difference between a piston type and the other, I think it's a wedge type. Does anyone have an opnion on one or the other, and what brands work best. I assume the more expensive ones are better, but unfortunately neither my father nor I placed the family beyond needing a budget.
All help appreciated
Jerry
Old 05-02-2005, 10:56 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I have used the piston type and wedge and IMO the wedge makes for a much more solid locking of the tools holder.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 05-03-2005, 02:39 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
I haven't used the piston type, so no comparision, but the wedge type Phase two is rock solid, and very repeatable. In a years time you won't be able to remember if the wedge type cost $30 more or $60 more. I have 11 tool holders for mine.
Regards,
Mark
www.wrathall.com
Old 05-03-2005, 08:14 PM
Thanks for the help.
Can you give a simple description of how the wedge works, it's not obvious from catalogue pictures.
Jerry
Old 05-18-2005, 12:19 AM
sch sch is offline
sch is on a distinguished road
The dove tail has a moveable part like a gib on the toolpost, it goes up and down as you turn the handle on the tool post and as the gib like part is on an angle, it moves outward and expands to lock the tool holder in the dovetail hence the wedge descriptor.
Steve
Old 05-18-2005, 12:31 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
In my experience they both are just as accurate.
The accuracy isn't the problem that I noticed, its the piston tends to wear or dimple the tool holder and that is were the accuracy changes starts. And I believe this is what paul maybe refering too.
Although I have a KD at work wich is supposed to be the "HIGH" end wedge style (and the price is to match) and have just about worn the wedge completely out. Although to be fair the tool post is probably as old as me!
I have a phase two wedge type i got for the mini lathe and i think I overkill the thing is for a big lathe (wanted to keep the tooling I use at work) should be good for some laughs when I get it tooled up and take some pictures. and the quality is good.
and that says it all.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 08:51 PM
CNC lathe tool and work offsets mm4039 General Metalwork Discussion 18 06-15-2005 12:45 PM
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 05:20 PM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 09:56 AM
First tool for the tiny lathe (home made) pics Stevie General Metal Working Machines 5 05-02-2004 11:24 AM
