Old 03-30-2010, 08:19 PM
mikeb87 is on a distinguished road
Talking moving to germany and have some questions.
I'm 22 years old and have been working for about two years now setting up cnc vmc mostly hass and mori seiki. I've worked on high production parts, molds, dies, and one off pieces. I'm about to move to hamburg germany for about 2 years and would really like to retain my position in this awesome industry.
What is the most common type machine used in germany? Doosan,mori seiki?? Also ANY information on what to expect from the machining industry out there would be greatly appreciated!!
Old 03-31-2010, 04:38 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Guten Tag,
Achtung baby! Expect to see extreme efficiency, cleanliness and precision. Have heard that engineers over there command the same respect as surgeons
It will be a fantastic experience and increase your knowledge exponentially. Not sure what the most popular control is over there, but it is likely you will see a lot of Heidenhain. Make sure you take a trip to Bavarian Motor Works!
I have recently relocated to New Zealand from UK, and although the work is on the other end of the scale in size and technical terms I have found the change quite refreshing and have definitely broadened my skills.
Good Luck! Let us know how you get on. Auf Wiedersehen!
DP
Trade offs between Moving Gantry and Moving Table gregmary DIY-CNC Router Table Machines 11 04-22-2011 01:48 PM
Questions about moving a renishaw OTS tool probe parkson Haas Mills 1 11-04-2008 07:19 PM
Moving Table Questions SPEEDRE DIY-CNC Router Table Machines 2 01-01-2008 10:47 PM
Moving table router design questions montanamac Open Source CNC Machine Designs 9 04-07-2007 09:27 PM
Moving Table vs Moving Gantry; Dremel vs Router chuckknigh DIY-CNC Router Table Machines 32 03-27-2007 08:48 PM
