Old 03-30-2010, 05:35 PM
heepofajeep is on a distinguished road
Best Small VMC?
We are going to purchase a new VMC, and I am wondering what the best "bang for buck" machine is that can fit through a 6'W x 7'H doorway, with a max Z height of 9'. I want as much travel as possible given the space constraints.
I am currently looking at the Bridgeport/HardingeGX480 because it seems to offer high travel with minimum space requirements-- any thoughts on quality of this machine?
Old 03-30-2010, 05:50 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Have operated both Bridgeport and Hardinge (a little larger than the one in question, around 1metre x-traverse) for about ten years and never had a problem with them. Have only used them with Heidenhain control.
DP
Old 03-30-2010, 06:53 PM
Thanks!
I edited the post a bit, just to make sure there are not any other small VMCs that I am overlooking. I created a specific post to investigate the quality of Hardinge/Bridgeport GX480 in the Bridgeport forum here.
Old 07-10-2010, 02:39 AM
doubledave is on a distinguished road
I have the first 480 delivered in the US. It has the Fanuc control 20 tool tool changer, & optional 4 spindle indexing fixture. The machine is bulletproof. Have never had a service call on it. Am considering buying another one just to avoid switching from index fixture to Kurt vises.
Old 07-10-2010, 10:39 AM
jdr jdr is offline
jdr is on a distinguished road
Look at Brother TC-S2C and Fanuc Robodrill machines.
Old 07-10-2010, 06:07 PM
Why?
Old 07-11-2010, 08:54 AM
jdr jdr is offline
You need to at least look at what a lot of machinists/companies are buying. Brother owns about 30% and Fanuc/RoboDrill owns about 60% market share in the small VMC market.
Old 07-11-2010, 09:24 AM
This leaves 10% for all the other manufacturers. What do you consider a "small VMC"? Haas has sold a lot of their Minimills and Super Minimills.
Old 07-11-2010, 09:33 AM
skullworks is on a distinguished road
You might want to also check out the Sharp 2412 and Hurco VM10, lot of bang for the buck in a small footprint. In fact the Hurco uses about the same space that a manual Bridgeport mill uses.
Old 07-11-2010, 10:09 AM
jdr jdr is offline
I wonder what heepofajeep did wind up purchasing? If anything.
Just noticed that it has been over 3 months since the start of this thread and he has not logged back on in the meantime.
Bridgeport-Harig 618 Ez-surf user manual needed simonr8126 Bridgeport and Hardinge Mills 3 04-18-2010 02:44 PM
Harding Talent & Fanuc Artitus Hardinge Lathes 3 05-14-2009 07:42 PM
Need Help!- HARDING CHNC II MadMan5000 Machine Problems, Solutions , Wireless DNC, serial port 9 04-17-2009 05:32 PM
Need Help!- Bridgeport Interact 308 user manual PLS.!!!! skywing Bridgeport and Hardinge Mills 0 04-12-2008 09:06 PM
Harding Drives fit a Bridgeport? Bill Gillen Bridgeport and Hardinge Mills 0 06-20-2005 06:52 PM
