Old 03-29-2010, 03:09 PM
davidscott is on a distinguished road
HMC CNC to grind HSS plate
Hello,
I look to buy a used HMC. The CNC will used 50% for aluminium and 50% for mold (D2) and HSS plate (M2) machining. I look for a used CNC because it is not for intensive machining time (1000hours/year).
Currently, HSS M2 plates (0.055"- 65HRC) are grinding at the local machine shop. The machine shop removed 0.005" each side of plate after heat treatment. They use a Norton Vitrified Wheels (5SG46).
My question is to know if it is possible to use HMC to grind the plates (with Electromagnetic chuck mounting on the pallet). The problem that I see is the diameter of the grinding wheel? I check to have grinder wheels of 5" and ajusting the RPM. The rigidity of the structure can allow this? This would avoid buying a grinder and it would be possible to have many wheels with different grit in the ATC.
The models I have looked are Makino a55, Kitamura H-400, Toyoda FA400 or Mazak HTC400.
Thanks,
David,
Old 03-29-2010, 05:02 PM
christinandavid's Avatar
christinandavid is on a distinguished road
Yes, it's possible to use a VMC/HMC to grind/lap. I have even done cylindrical grinding using a 12" diamond lap on a VF4 and using the Rotary table as a spindle (it didn't do it much good).
Things to bear in mind are: - Tools clashing in ATC - Inputting the wrong figure (big crash) - Machine accuracy eg I was circular pocketing one job with a grinding wheel and had to experiment with the feedrate to finetune the size/circularity. There is no substitute for a conventional/CNC grinder.
DP
Old 03-29-2010, 05:38 PM
Grinding on any machine other than a grinder is an excellent idea providing destroying said machine is the objective. Just because it can be done doesn't make it a good idea.
Dick Z
DZASTR
Does anybody grind their own endmills in house? ryanschmidt224 General Metalwork Discussion 1 02-22-2010 01:23 PM
Any tips for designing a fixture plate / tooling plate? thackman Benchtop Machines 9 12-19-2008 11:26 AM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
surface grind gibs? phantomcow2 General Metal Working Machines 0 06-11-2006 07:10 PM
Grind my bearings? Oldmanandhistoy Linear and Rotary Motion 20 02-18-2006 07:53 AM
