Old 03-28-2010, 08:51 PM
emh114's Avatar
emh114 is on a distinguished road
0.005 inch cut???????
OK Here is the question....
I would like to cut a piece of silver or brass circle across the face, but i need the small kerf I read somewhere that this has been done with a .005 inch blade. what saw uses this blade and where can i get one...
thank you for you help on this
Sebashtion H.
Old 03-29-2010, 07:00 AM
Boots is on a distinguished road
Have you checked with the CIA ?
We all live in Tents! Some live in content others live in discontent.
Old 03-29-2010, 02:18 PM
keebler303 is on a distinguished road
EDM or a small endmill would both work.
Matt
Old 03-29-2010, 03:30 PM
Andre' B is on a distinguished road
Slotting saw, use on any good mill.
http://www1.mscdirect.com/CGI/NNSRIT...10159&PMT4NO=0
Old 03-29-2010, 04:25 PM
M250cnc's Avatar
M250cnc is on a distinguished road
Sebashtion
How deep does this need to be ?
What is the slot for ?
Why the questions, different answers give different solutions.
Phil
Old 03-29-2010, 05:19 PM
emh114's Avatar
Matt
What is a EDM????
Sebashtion H.
Old 03-29-2010, 05:24 PM
emh114's Avatar
Originally Posted by M250cnc View Post
Sebashtion
Phil
cutting straight threw the circle about 2mm thick. Min waste needed..
Sebashtion H.
Old 03-29-2010, 06:51 PM
M250cnc's Avatar
The slotting saw someone else mentioned, but holding will be your next problem.
What is EDM http://en.wikipedia.org/wiki/Electri...arge_machining
Phil
Old 03-30-2010, 08:11 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
Originally Posted by emh114 View Post
What is a EDM????
Sebashtion H.
found this neat video
Old 03-30-2010, 11:18 PM
emh114's Avatar
sorry wrong thread....
the slot cutter looks like the way to go... but I dont have a mill yet......
Sebashtion H.
  #11   Ban this user!
Old 03-31-2010, 07:08 AM
EDM=Electrical Discharge Machining. Usuallay done with shaped Carbon Electrodes or Wire.
  #12   Ban this user!
Old 03-31-2010, 09:32 AM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Woah, that's an expensive slitting saw!
Paul
Problem- Best way to mount 1/16 inch ball mill with 3/16 inch shank in router. cjjonesarmory Wood Working Tooling 10 07-02-2009 05:38 AM
MM to Inch? esadaddy Fanuc 3 01-31-2009 08:19 AM
cnc cut 1 inch alum? Todd W General Metalwork Discussion 4 04-29-2008 07:40 AM
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 02:06 PM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 09:27 AM
