Old 03-25-2010, 11:05 PM
thedave is on a distinguished road
Is this correct: For Oilite Bearing Install
I am borrowing time on a friends machine for a prototype I am working on. I need to install (2) Oilite bearings in a 2" x 2" x 3" block of 6061 Aluminum. I will be machining a hole through the length in the center of the block. There will be a bearing at each end. The bearings are 1/2" x 5/8" x 3/4" the OD is marked .628 / .627 on the package. I need to check my research. I need to perform the following tasks:
1. Square everything up.
2. Start with center drill.
3. Drill through with 3/8" drill (slow, with fluid)
4. Drill through with 19/32 Drill
5. Ream with 5/8" Chucking reamer.
Questions:
For the last drill should I use a 39/64 in place of the 19/32?
Should the reamer be strait or spiral?
Is a 5/8"chucking reamer the correct size for the bearing.
I will have access to a lathe and a mill (smithy 3 in 1), is this task better suited to the mill or lathe?
What else did I miss?
Thanks,
Dave
Old 03-25-2010, 11:35 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
best off to put it on a lathe and bore it
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 03-26-2010, 10:41 AM
packrat is on a distinguished road
The old "rule of thumb" for drill size before reaming is- Up to 3/8" -1/64" undersize, over 3/8" -1/32" under size.
cary
How to align/calibrate/install first linear bearing ? Calico DIY-CNC Router Table Machines 10 10-25-2009 11:00 AM
Newbie- BK/BF12 bearing how to install ? galoz DIY-CNC Router Table Machines 10 10-22-2009 01:46 AM
Need Help!- Thrust Bearing install question mhackney Benchtop Machines 2 03-25-2009 07:51 AM
How To Install Angular Contact Bearing on Ballscrew. bcromwell Linear and Rotary Motion 5 02-27-2008 10:45 PM
WTD: Oilite Information Al_The_Man General Metalwork Discussion 3 08-20-2005 07:36 PM
