Old 03-21-2010, 01:01 AM
binfordw is on a distinguished road
Help with setup- Centering roundbar
I am wondering what is the correct way to setup a round piece of stock in my mill to be drilled/milled in center.
Example, A 1.75" dia solid barstock, cut 2" long or so and clamped in a vice vertically with a v-block. Whats the best way to find the center of the bar to drill a hole in it?
Thanks in advance,
Ben W
Old 03-21-2010, 03:57 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Ben,
A combination square with a center head is one way.
Two intersecting lines will do the trick.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-21-2010, 10:14 AM
If it needs to be very accurate, use a dial indicator to find exact center by tramming the OD.
Dick Z
DZASTR
Old 03-21-2010, 03:42 PM
Enraged is on a distinguished road
a coax indicator would be the best way. for reference, Glacern has a great video: http://glacern.com/index.php?page=vi...course_mill_05
FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
A BETTER TAP WRENCH! SELF CENTERING! northernmach Product Announcements & Manufacturer News 19 08-28-2010 01:13 PM
Need Help!- Hole centering ??? whitehedr Mini Lathe 4 12-27-2009 08:01 AM
Need Help!- Need help with Set-Tru chuck centering dpseafish General Metalwork Discussion 10 03-16-2008 07:14 PM
centering problem settingbur CNC Swiss Screw Machines 2 03-07-2008 06:47 AM
Centering a 4-Jaw chuck gdl357 Mini Lathe 10 09-20-2004 05:24 PM
