Old 03-20-2010, 12:33 PM
Coryc is on a distinguished road
Have the milling machine, now I need tooling
Hey, new guy here. Just to start off I have very little machining experience.
I've recently bought a 10" x 18" Craftex lathe and a Craftex milling/drilling machine second hand from a fella who stepped up to bigger equipment. I have used the lathe quite a bit and have some very basic knowledge learned in Highschool( 20 years ago!) and from videos on youtube.
I just got the mill wired in and have not used it at all. I have no tooling yet and really don't know what all I should buy. I know I need a clamp set, but the end mill holders has me confused.
It has an R8 taper, which I'm told is a very common type? I see R8 end mill holders that seem to only hold one certain size. Then I see R8 collets. Can I buy one end mill holder that will take all the collets that fit all the sizes? or do I have to buy a holder for every size end mill? Or do the end mills only have 1-2 shank sizes? I don't even know how they stay in the holder... Damn I have a lot to learn
I'm very excited to get going !
Thank you
Old 03-20-2010, 01:15 PM
Bubba's Avatar
Bubba is on a distinguished road
Cory,
Holding the tools is commonly done with either a collet OR an endmill holder. The endmill holder is arguably more rigid than a collet, but like you say; it will hold only one size shank. A set of collets can be had for a reasonable price from the usual discount places and do a reasonable job until you have things sorted out. In either case, the holder is retained in the quill by use of a drawbar that goes down through the center of the spindle and for R8 has either a 7/16-20 or 12mm thread on it depending on country of origin! Most of what you will find on this side of the ponds I think will be 7/16". As for end mills, I got a cheap set from Enco to begin with to see how things would work on my machine. I quickly found out which sizes I use the most and that is what I attempt to keep on hand. I rarely wear one out as I have a nasty habit of breaking them off before that happens (hey, I am still learning:})
Alot will depend on WHAT you intend doing with your machines.
Art
Old 03-21-2010, 06:28 PM
binfordw is on a distinguished road
I have a small X3 mill with an R8 taper, I bought this http://www.grizzly.com/products/R-8-...-pc-Set/T10068
If I was starting again I would probably go with a different manufacturer, and a kit without all the big collet sizes, but it has worked for every bit and endmill I've needed to stick in the spindle so far.
As far as endmills, I buy alot of .187" to .375" endmills from Maritool.com I have a few 1/2" bits I use for facing and stock removal.
Old 03-24-2010, 12:05 AM
Thank you for the replies, that really clears things up for me.
I already have a list of things I'm going to buy and I think I will get a cheap set of end mills and the collet kit to start out with.
Old 03-24-2010, 12:11 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
some of the er sets on ebay are pretty good and cheap , i picked up a 10pc er16 set with a 1/2' shank holder to use on my router for about $35-$40 , it runs pretty true and great at 25000rpm (though they are meant to run at those speeds)
this is one seller for example
http://shop.ebay.com/hk_tools/m.html....c0.m14&_pgn=3
if you want low cost carbide or hss endmills then pm me if you'd like , I can work something out for you to get a decent start up set going
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 03-24-2010, 11:02 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Remember to tram the head on your mill and check the table for burrs or dings (stone them down) before you start cutting!
I love deadlines- I like the whooshing sound they make as they fly by.
Old 03-24-2010, 05:23 PM
Loyd is on a distinguished road
Tooling
Cory,
A good place to get tooling and some good deals is:
GLC Sales
"Wolf"
877-742-2224
I have been buying tools from there since 1986.
Hope this helps.
Tell Wolf "Loyd sent you"
Loyd
Old 03-24-2010, 09:22 PM
Ok, now you got me confused again. What does "tram the head" mean exactly?
I just checked the table and it feels very smooth. This machine is almost new.
Old 03-24-2010, 09:37 PM
Tramming
http://www.webs1.uidaho.edu/mindwork...Head%20pdf.pdf
It is a method of making the spindle centerline perpidicular to the table of the mill......very important! Also deburring (with a fine stone) the table and vise, angle plate, workpiece or whatever you are mounting to the table.
Loyd
Old 03-24-2010, 09:52 PM
Ah! Thanks for the info. I just printed that out. I'll keep a copy of that handy.
One more question: What kind of rpm do I use for most milling operations? I know that's a pretty vague question. I would think steel and aluminum would be different, and also different sppeds for different operations.
The manual that came with the machine doesn't tell me anything. I really need to buy a book, or video. Are any of these videos I see advertised worth it?
As far as what I'm going to work on I'm not sure. I will likely clamp a chunk of aluminum in there first and go at it, just to see how it all works. All I know is I'm like a kid at Christmas waiting to try this thing out !
Old 03-24-2010, 11:11 PM
dertsap's Avatar
Gold Member
some speeds and feeds for standard end mills and materials
Just IN- Hevi-Rail® Clears Way for Machine Maintenance and Tooling Pacific Bearing Product Announcements & Manufacturer News 0 08-03-2009 02:29 PM
Okuma LC20 With Milling/Live Tooling ??? davtbarber Okuma 1 02-22-2008 02:01 PM
Helical Bore Milling Tooling Ginger_Ninja54 CNC Tooling 2 01-19-2008 09:15 AM
Save 100% on Tooling cost and set up time on milling thin parts with the Doo-Bee Stop DynaPowernamics Product Announcements & Manufacturer News 5 05-28-2005 09:17 PM
best tooling purchases made for building your CNC machine pminmo DIY-CNC Router Table Machines 15 04-09-2004 09:28 PM
