Old 03-19-2010, 11:43 PM
banctecbobn is on a distinguished road
+What mill to purchase?
Hello,
I need good advice on which manual mill (new or used) to purchase within $3000. It will not be used in production, just hobby. Nothing less in size as a RF45 and not bigger than a bridgeport. Would like to CNC in the end.
I was pretty much sold on the Industrial Hobbies manual mill but they have some quill slop. Kinda like the lathemasters mill but might not be big enough. I currently have a Shoptask Gold series 3in1 and am looking for better.
Have a great day,
Bob
Old 03-20-2010, 04:05 AM
aucran is on a distinguished road
The quill slop on the IH mill that gets publicity isn't really that terrible. Unless your hobby needs require very accurate tolerances it would probably never bee an issue.
I was worried about it initially too, but I hardly ever extend my quill beyond three inches for the work I'm doing. Just something to consider though, even if it does have its problems they may not limit you very much depending on your application. For me I think it was good investment, but I've only had mine for a few months and made a dozen or so parts on. All turned out well so far though.
Old 03-20-2010, 04:59 PM
I've been warned by others about the IH quill slop.
I want/need to be able to machine a 3 inch square with all sides being a near perfect 90 degrees to each other without any repositioning. The sides should be within +/- .001 . Also need to be able to machine a cylinder bore.
Don't get me wrong, I really like the IH mill. Just wondering if I would be better off with a good used piece of iron. Maybe a Bridgeport/clone or maybe a Tree. I'm not a machinist and have only used my Shoptask and a badly worn out Bridgeport (just once) in the past.
Old 03-20-2010, 05:38 PM
packrat is on a distinguished road
Can't go wrong with a Bridgeport or BP clone!
Old 03-22-2010, 01:52 AM
steveb946 is on a distinguished road
Vertical mill under $3000
You might have a look at the Grizzly G3103 (6x26 inch table manual knee mill).
I have one and am generally pleased with it.
The quill is sloppy when extended.
It has a 2HP motor and an R8 spindle (which can be converted to and ER32 quick change collet from Shars tool Co).
I am toying with the idea of converting the mill to CNC, so will let the appropriate forum here with my decision and any progress.
Steve
Need Help!- Advice on new mill purchase BigDog66 General Metal Working Machines 1 12-02-2009 01:49 AM
Would this indexable end mill be a bad purchase for a hobby mill? Oldmanandhistoy General Metalwork Discussion 38 03-10-2008 09:20 AM
Purchase of CNC Lathe & Mill Dave1978 General Metal Working Machines 1 10-24-2007 06:51 PM
CNC mill purchase 9 1/2 Bridgeport and Hardinge Mills 1 02-09-2007 02:04 PM
CNC Mill Purchase advice sigipa General Metal Working Machines 10 02-08-2007 02:57 PM
