Old 03-16-2010, 05:27 PM
Gavcarter is on a distinguished road
Question Milling Machine.
Hi all Just after some advice on building a relatively small and simple milling machine.
It will only need a Z axis as i am planning to use a good quality cross vice to control the X and Y (at least to start with).
The main problem I am encountering is spindles/chucks - there are so many types and i would much prefer if i could get away with something simple like a drill chuck (for holding the tools - obviously this needs holding to a much more secure spindle than it came from)
What should i be looking at when thinking about the main spindle? I know the bearings must be up to the job but do they HAVE to be tapered as this makes building the machine a lot harder.
Im just running ideas as yet i have no real idea what exactly is required to build something useable.
It will be made for small jobs on aluminium and brass - doesnt need to be ultra accurate but it needs to be able to mill a straight line in a (to the eye) prefect straight line. The pillar drill just cant do it - the chuck and shafts wobble (bearings are probably shot).
Many thanks for any help!
Gavin
Old 03-16-2010, 05:38 PM
john huijben is on a distinguished road
I think getting a sturdy drill press, and modifying that with a crosstable is your best option
Old 03-16-2010, 06:42 PM
BioMicro is on a distinguished road
When you say you only need the Z axis, you don't mean you only drilling, right? Which means you will be side-loading the spindle. So a drill press is out. Drill press bearings are made for axial loading. Radial loads will cause all kinds of chatter, wobblies, and assorted goofiness.
There are some cheap solutions and creative ideas around for mill bearings but this is why the spindle bearings on a mill are always so darned $$$$.
Old 03-17-2010, 10:41 AM
Drill chucks are for drills, NOT for milling cutters. Drill chucks are not very secure, even for small tools, and generally not accurate enough for milling. Wobble etc.
Dick Z
DZASTR
Old 03-18-2010, 08:31 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
By the time you buy/build a spindle and then buy a "good quality cross vice to control the X and Y " - you might as well just buy an X3 style machine and save a few bucks and a lot of headaches.
www.integratedmechanical.ca
buy milling machine miropio Want To Buy...Need help! 3 02-04-2009 12:07 PM
Want to get my own milling machine. timbo.nz Industrial Hobbies (Support forum) 1 10-19-2007 04:33 AM
CNC milling machine ebproseller Mechanical Calculations/Engineering Design 15 06-24-2007 08:58 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
