Old 03-15-2010, 05:54 PM
BioMicro is on a distinguished road
Collet size for Logan 820 Lathe?
I'm setting up my old Logan 820 and it has no collets. The lathe came with the closing sleeve, draw-in spindle, etc. Everything BUT collets. It looks like the end of the draw-in spindle has maybe a 5/8-18 inside thread, (hard to tell) but measures about .597" ID. The collet adapter has an outside 3MT taper, and is shaped for the collet inside, with an anti-rotation pin. It's only marked Logan Manufacturing but no call-out for the taper or collet type.
So what collet goes in there? Perhaps a 3AT? I've read elsewhere that the 3AT is similar in diameter to a 5C, but no way - a 5C has outside threads of about 1.23", and a 3AT is closer to a half-inch or 9/16". (You can see my frustration!)
I got this old thing from wife's grandpa, it's a 1946. But it was reasonably good iron for a small lathe. Check out the old manual that grandpa kept...
Name:	Logan Manual pg 15 crop.jpg‎
Old 03-15-2010, 06:19 PM
packrat is on a distinguished road
Here is a size chart for lathe collets. I found it here; http://bbs.homeshopmachinist.net/showthread.php?t=29215
cary
Old 03-17-2010, 07:08 PM
Thanks. After more research, it appears 3AT is the correct collet. eBay time.
Newbie- Logan Lathe Conversion tiredengr General Metal Working Machines 0 01-25-2010 11:05 AM
Trying to buy a Logan lathe FrankieC General Metal Working Machines 1 08-05-2009 09:25 PM
CNCing a Logan Lathe Too_Many_Tools Vertical Mill, Lathe Project Log 7 11-28-2008 10:35 PM
I found an old logan 850 lathe for 100 bucks is it worth it? trilect General Metal Working Machines 4 06-29-2005 04:52 PM
What is this collet size? kong General Metal Working Machines 2 06-06-2004 01:07 PM
