Old 03-15-2010, 11:12 AM
gorillam is on a distinguished road
Fanuc T16I w/Tsud 4th axis not clamping.
I bought my fanuc robodrill t14ia with the t16 controller the unit comes with a tsud koma 4th table with a schunk clamping table, I am having problems clamping the hydraulic schunk table.
I go to menu 7 in the controller, which is table clamp/unclamp and try it but nothing happens. It also gives me the system message, clamp unfinished.
Before I spend a ton of time trying to get the 4th working I was wondering is there a parameter that over-rides needing to have the table clamped to run operations. Because if I try and MDI or turn the spindle the controller pulls an alarm saying it can not run until the table is clamped.
I know and understand the risk of why the alarm comes on but I just need to do a few simple parts asap I will figure out how to fix the 4th or schunk table after.
clamping methods? Crawler374 DIY-CNC Router Table Machines 7 12-08-2009 05:44 AM
clamping options Drools DIY-CNC Router Table Machines 7 08-07-2009 08:53 AM
Newbie- Clamping with a rod thatstephen General Metal Working Machines 3 05-08-2009 12:00 AM
Clamping Threaded Rod? JWB_Machining General Metalwork Discussion 10 02-27-2009 06:52 PM
Newbie- Fanuc 21mb 4+1 axis want to make 5 axis rebirthauto Fanuc 0 09-17-2008 07:47 PM
